Nevada Chapter Join Chapter, Leader:67 Olfthfl
5.4L secondary cam chain timing marks?
Old 12-23-2012, 03:47 PM
Gembone's Avatar
Gembone
Gembone is offline
hey all,
trying to get a truck for a friend put back together for him.
I am working with a 5.4L 32-valve DOHC V8 from a 10/99 Navigator.
He brought me the truck with the heads off and fresh from the machine shop.
The machine shop removed the secondary cam timing chains when they cleaned the heads but didn't mark them.
I need to know where to line up the cam secondary gears to get the chains lined up properly.
I have a printout for the main timing chain timing marks but not the secondaries.
Any one out there got a link or possibly access to all-data that might give me this info?
I still have the heads off the motor so that I can rotate the cams into position without bending a valve.
So info about possibly changing the cams that tells how to properly align from scratch?
Thanks
Old 01-08-2013, 11:14 AM
Gembone's Avatar
Gembone
Gembone is offline
UPDATE: The only info I was able to find prior to today was to align the timing mark on the cam gear with the colored link in the secondary chain.
Originally I thought my chains didn't have the off-colored link but I gave them a good cleaning and managed to find those links. Yay for me!
My friend got the machine shop to also take a look and set them if my alignment is incorrect.
He will be taking the heads back by there today.
I will keep you updated if my timing was right or wrong.
Also thanks to SDV10 who posted the pick of the cam gear timing from the Navigator shop manual in his tech stuff album.
Will be very helpful for those that don't have the colored chain and can count links.
Mikerage
1997 - 2003 F150
30
07-29-2016 02:59 PM
Gembone
Modular V8 (4.6L, 5.4L)
01-08-2013 10:40 AM
keg
10-29-2009 07:51 PM
v8only
08-26-2007 03:28 PM
Elk6969
1978 - 1996 Big Bronco
03-29-2002 07:09 PM
Quick Reply: 5.4L secondary cam chain timing marks?
