429 tunning problems - Ford Truck Enthusiasts Forums
Old 12-25-2012, 05:13 AM
jeckman jeckman is offline
jeckman is starting off with a positive reputation.
So here is my setup, 429 bored .030 over, zero decked with stock 1973 style dished pistons, pocket ported dove-c heads with 2.19 intake and 1.76 exhuast valves, x4256h cam,striaght up timing set, 1.7 to one ratio crane blue racer rocker arms and custom made pushrods. Ignition timing right now is set at 15 btdc initial 39 degrees total with 10 degrees of vacuum advance, carburetor is an edelbrock 1411 750cfm. my problem is mid throttle bog, doest matter which jets, rods or springs i use i get the same issue in varying degrees, could this be a problem with my build or with the carb?
Old 12-25-2012, 05:29 AM
forgot to mention the engine is estimated at 10:1 compression and is in a 79 bronco c6 tranny with stock converter and 3.50 gears
Old 12-25-2012, 01:30 PM
big vann big vann is offline
big vann is gaining momentum as a positive member of FTE.
What are the cam specs?Lift,duration @ .050.What intake manifolld?Got headers?Sounds like carb though.Holleys are much easier to set up for a performance application.I don't know much about Eddy carbs,but I know they work better on stock style builds.I know that jets(on a Holley)won't contribute to a bog or stumble.I would look at the secondary operation.Also narrow down wether it's a rich or lean bog/stumble.Black smoke out of tailpipe at time of bog is rich.Lean would be white smoke.If you have a vacuum gauge connected to the engine and you can see the reading at the time of the bog,the vacuum reading can tell you if it's the primary or the secondary circuit.Make only one change at a time to avoid confusion.Maybe try Edelbrock website for specific tuning.
Old 12-25-2012, 03:52 PM
cam specs are 256 intake 262 exhaust, duration at .050 is 210 intake 218 exhaust. lsa is 111 degrees lobe lift is .299 intake and .298 exhaust. im getting about 17" of vacuum at idle. I have the stock dualplane manifold and ported stock truck exhaust manifolds. Im not noticing any smoke black or white, but I pulled the #1 spark plug and its white no coloring what so ever, I put slightly smaller metering rods in the carb to richen it up a bit WOT got better but mid throttle criusing got worse. Secondary circut seems to work fine. Ill drive around with a vacuum guage and let you know what I find
Old 12-27-2012, 03:18 AM
My fuel pressure was running too high, I didnt know eddys needed 6 psi or less I must have skipped that part in the manual lol. I installed a pressure regulator and it solved the stumble. Thanks for the info.
429 Crankshaft Timing 1977F250RANGERXLT 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-18-2015 05:31 PM
What grade gas for a 429 maytea 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-19-2015 11:27 PM
Big engine, little truck - 429 build advice fiftyfordfloored Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 03-23-2015 09:43 AM
390 vacuum advance timing 1975FordF250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 19 07-04-2014 02:51 PM
429 swap fail. Need help please!!!! cfordmanh68 1973 - 1979 F-100 & Larger F-Series Trucks 11 05-18-2014 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
