Removing CD from 6 CD changer - Ford Truck Enthusiasts Forums
Old 05-25-2003, 10:42 PM
WillW WillW is offline
WillW is starting off with a positive reputation.
Unhappy Removing CD from 6 CD changer
OK, I know I should have read the manual completely, but I was an idiot. I put one CD in the changer in position one on my 2001 Sport Trac. A few hours later as we are traveling my wife is reading the manual and reads the part that says no CD with stick on labels should be used. That is the kind I grabbed and put in the system to try it out. I went directly to the eject button, but like it says, do not put one in the system. When I attempt to eject it says CD error and door is open. Radio still works. If I am able to cleanly pull the radio out, will I find a way to remove the jammed CD.
You do not have to say it, my wife has already said and will continue to say all those positive things about my error.
Thanks,
Will
CD Error - Suggestions to Fix or Replace? Todd Fuller 1997-2006 Expedition & Navigator 2 01-12-2015 02:47 PM
F150 CD-6 Changer Locked up/Stuck Dudster 2004 - 2008 F150 3 07-25-2011 04:56 PM
Stock 6 Disc in dash MP3/CD changer evilwayz7 2004 - 2008 F150 4 08-28-2009 01:49 PM
Are You Having Problems With Your In-Dash 6 CD Changer? brian42 1999 to 2016 Super Duty 7 11-12-2008 08:29 AM
cd changer cartridge stuck D Ray 1997-2006 Expedition & Navigator 4 05-25-2006 03:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
