something ive always wanted to know - Ford Truck Enthusiasts Forums
Old 12-24-2012, 12:21 PM
npd23 npd23 is offline
npd23 is starting off with a positive reputation.
ever since i first got my 93 f150 ive always wondered to myself how much higher the stock 4wd 250 sits compared to something like my stock 4wd f150. i love the look of the stock f250s with 33s on it and i really would like to know how much lift i need to sit exactly like that..
Old 12-24-2012, 01:12 PM
woosterken's Avatar
woosterken woosterken is offline
woosterken is starting off with a positive reputation.
every body here on the forum says to put the coil springs from a 250 in our 150 , it will give like 2" of lift to the front.
there should be enough room in the rear for the 33's
with the spring change you will not need longer shocks,unless your going major off road.
ken
Old 12-24-2012, 01:36 PM
MaineFordLover93 MaineFordLover93 is offline
MaineFordLover93 is starting off with a positive reputation.
Have a 94 f-150 and i put the 2 inch leveling coils from jeff's bronco graveyard and tried and tried to get the camber right but ended up bringing it too a shop and they couldn't figure it out so i had to buy the 2 inch i-beam drop brackets another 150 bucks!!
Old 12-24-2012, 02:31 PM
thanks so much! I ended up putting a full two inch lift in it now I just need the money to actually get tires! but I ordered and installed coil spring spacers and a inch and a half block for the rear I was just concerned on if that'll sit it like a stock 250 with bigger tires cause it's hard to tell with stock tires !? thanks for the help guys!
F150 to F250 suspension swap... 4601ton 1987 - 1996 F150 & Larger F-Series Trucks 21 05-24-2015 01:03 PM
2wd vs 4x4 ride height Jarryd 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2014 04:50 PM
Tire replacement on my 09 2wd S-Crew? fordjunkyNC 2009 - 2014 F150 19 01-27-2014 11:48 AM
2wd and 4wd Truck Heights Rick_Fury 1987 - 1996 F150 & Larger F-Series Trucks 4 12-22-2011 11:53 PM
Pics of f150s stock on 33s needed! 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 7 03-01-2010 09:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
