NO VOLTAGE AT FUEL PUMP AFTER REPLACING
Check fuses F19, F24, & F30 under the hood along with the PCM Power and Fuel Pump relays, all under the hood. Keep in mind that the fuel pump is turned on by the PCM, so it is necessary that the PCM is properly powered and operating before the pump can be turned on. If the MIL comes on when the ignition is switched to ON, the PCM is at least receiving power.
...and fix your CAPS LOCK key, it appears to be stuck in the ON position.
Yes i know but i have two expos and the same thing happen to that one so its safe to say i assumed. but i wont have to worry about changing the fuel pump again its brand new
hey guys, a little help? 1997 expy 5.4 ive had an issue where i turn the key and i get no crank, the i cycle the shift lever and then the car will crank and start . recently i went to get gas , went to star and it wouldnt crnk so i did the usual and it didnt crank , changed the starter and it still wont crank and not sure what it could be all connections are good and power too. what else could it be?
97 expy cranking issue
drudis
02-12-2010 11:34 AM
