You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well today...I took some time to do my 1st oil change on the new girl. Kind of hard to believe it takes 7 qts! LOL But...at just over 5100 miles...I felt before the weather gets harsh...do it now.
So...the 16mm oil plug was a snap to remove. Broke it loose...and used fingers to work it off the rest of the way. Pulled 5gal oil pan up...and caught all the oil as it flowed fast and with force. Whew...no oil on the floor!
After all the dripping...and a quick wipe of the oil pan...I installed a new Fumoto F-106 oil drain valve. Prior to installation...I prep with lock ring and dust boot. Install hand tight...and using a wrench tighten another 1/8 - 1/4 turn after. Nice clean install.
Used Motorcraft FL-820s oil filter. OEM oil filter came off easy...but under pressure with a good amount of oil flow. Again...no OIL on floor! Thank You second oil pan!
Did a visual on entire under and engine compartment...and happy to report still looks new! Now...6 months or 10,000 miles until the next oil change...whichever comes first!
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
Thanks for mentioning the Fumoto valve. I used to have one of those on my old truck 25 years ago and it made oil changes a breeze. After I sold the truck I figured I could find a new one at the local parts store but no luck. No internet then and after a while I just stopped looking. I just ordered four for the fleet, woo hoo!
