1986 F-250 Progress Thread
#872
Thanks. I looked at the bumper today in the sunlight, wow it looks way better now than it did last night! I can't believe it hid every single imperfection on that bumper lol. I'll be doing the rear next weekend most likely the same way.
#873
#874
#877
I got my carpet kit today. Laid it out in the bed for a few hours and will do that tomorrow and before I install it while I remove the seat. Looks like it should fit well. It sure looks to be of good quality. It's an ACC carpet kit. Even came with the hi/low beam switch grommet. It's even got insulation held to the carpet up to the seat area.
#879
#880
I got the carpet installed today. That was the easiest carpet job I've done. It required no trimming except the top right corner to clear the floor vent and cut the bolt holes out and the dimmer switch. Fit perfectly.
I also re did the floor kick panels, flaked all that vinyl and fabric dye off it and resprayed them with the spray bed liner. It looks the same ironically, should be much more durable this time. I also sanded my grungy looking door sill plates and sprayed them as well. I'll post more pics once the small stuff is put in.
#883
#885
It sure does. The vinyl mat I took out ripped in several places without even trying, it was rotten. I used it as a ground over spray protector for the kick panels before I rolled it up and threw it in the trash. Maximum usage!
What truly impressed me was the width was spot on perfect. I was expecting to trim it quite a bit.
