ABS Light 97 F350 - Ford Truck Enthusiasts Forums
ABS Light 97 F350
Old 12-23-2012, 07:02 PM
maytag906's Avatar
maytag906 maytag906 is offline
maytag906 is gaining momentum as a positive member of FTE.
ABS Light 97 F350
I have a 97 F350, 5.8 auto. When I first start it and start driving, the ABS light will come on. But 9 out of 10 times, if I activate the left or right turn signal, it goes out. The other 1 time it will stay on, until I shut down. It might repeat later, it might stay off all day.
Something to worry about?
Old 12-24-2012, 03:41 PM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC Chapter LDR
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
Quote:
My passenger car is a 98 Volvo. It has an intermittent ABS light that my mechanic said was due to a sensor problem. I learned to drive before ABS was invented, so I would say "nothing to worry about." Your stopping distance may be longer on slippery pavement since humans can't modulate the brakes on and off as fast as ABS, but then I'm not a big fan of tailgating when the pavement is slick!
Also, I'm guessing it won't be long before another wheel's sensor detects the issue and tells the computer to brake as fast as possible.
97 F-350 ABS and emergency brake lights on suddenly meb9796 Brakes, Steering, Suspension, Tires, & Wheels 6 12-22-2009 03:07 PM
ABS light stays on riverratba 1999 to 2016 Super Duty 8 12-09-2009 09:29 PM
Possible GEM failure? mjorda2 1999 - 2003 7.3L Power Stroke Diesel 8 12-14-2007 08:22 AM
ABS Light ASR GUNS 1997 - 2003 F150 10 02-26-2007 11:39 AM
ABS codes? habsfn 1999 to 2016 Super Duty 2 07-09-2005 07:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
