4x4 hop - Ford Truck Enthusiasts Forums
4x4 hop
Old 12-23-2012, 04:47 PM
fordsuperduty250 fordsuperduty250 is offline
fordsuperduty250 is starting off with a positive reputation.
4x4 hop
I have a 1993 ford f150 4x4 with a 4.9 straight six. Whenever I put it in 4wd I notice it kind of hops or jerks when I start to turn. Is this normal?
Old 12-23-2012, 05:12 PM
MEDF150's Avatar
MEDF150 MEDF150 is offline
MEDF150 is starting off with a positive reputation.
Yes, especially with limited slip or locker differentials
Old 12-23-2012, 05:47 PM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
Yes its normal, especially if you're on dry pavement. Shouldnt be in 4wd on dry pavement though, can cause things to bind & break.
Old 12-24-2012, 12:50 AM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Some light bouncing and jerking with the wheel almost fully turned is normal, and I do mean light.... my 94 4x4 F150, when I first got it, had a seized front axle U-Joint, and as soon as I start turning, would make these big clunking noises and bouncing and jerking....
Might wanna check your U-joints! Also, try avoiding turning the wheels fully on either side when in 4x4, weather on pavement or mud/snow.
Old 12-24-2012, 01:32 AM
Plain Jane Plain Jane is offline
Plain Jane is gaining momentum as a positive member of FTE.
The harder over you turn the wheel the more hop you are going to get when you have traction in 4x4 mode. The wheels are turning at the same speed, but the distance traveled by the inside wheel is less than the outside wheel in a turn, so one of the wheels is breaking traction to keep up with the other. Don't use 4x4 mode if you have good traction. Just shift out back to 2wd.
Old 12-24-2012, 01:38 AM
Puddy's Avatar
Puddy Puddy is offline
Puddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to beholdPuddy is a splendid one to behold
Normal, otherwise if you cant live with it, you can perform the 2k upgrade of RCV
Old 12-24-2012, 11:50 AM
gjgarre's Avatar
gjgarre gjgarre is offline
gjgarre is gaining momentum as a positive member of FTE.
Sounds familiar, my truck when I got it had two seized up front U-joints, and when I first drove it down the street, they wouldn't let me turn the wheel, and suddenly they decided to turn the wheel on their own, and shot me into oncoming traffic. Scary, but I have since taken care of it. Probably the reason my hubs were nothing but metal flakes inside, and had to be replaced as well.
Hop !!!! bakerbuilttracks 1999 - 2003 7.3L Power Stroke Diesel 10 01-23-2012 04:46 PM
08 f250 4x4 Wheel Hop, you gota be kidding me! Mike SVOR 1999 to 2016 Super Duty 6 10-17-2007 10:05 AM
rear end hop fisher1995 1987 - 1996 F150 & Larger F-Series Trucks 12 03-09-2007 11:28 AM
how to get rid of wheel hop? canadianSD 1999 to 2016 Super Duty 2 02-07-2004 08:49 PM
4x4 Wheel hop Ranger 1999 to 2016 Super Duty 15 10-17-2000 02:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
