Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Nevada Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Nevada Chapter Join Chapter, Leader:67 Olfthfl
  #1 (permalink)
Old 12-23-2012, 03:47 PM
Gembone's Avatar
Gembone Gembone is offline
1970 Ford F-100
Gembone is gaining momentum as a positive member of FTE.Gembone is gaining momentum as a positive member of FTE.
5.4L secondary cam chain timing marks?
hey all,
trying to get a truck for a friend put back together for him.
I am working with a 5.4L 32-valve DOHC V8 from a 10/99 Navigator.
He brought me the truck with the heads off and fresh from the machine shop.
The machine shop removed the secondary cam timing chains when they cleaned the heads but didn't mark them.
I need to know where to line up the cam secondary gears to get the chains lined up properly.
I have a printout for the main timing chain timing marks but not the secondaries.
Click the image to open in full size.
Any one out there got a link or possibly access to all-data that might give me this info?
I still have the heads off the motor so that I can rotate the cams into position without bending a valve.
So info about possibly changing the cams that tells how to properly align from scratch?
Thanks
__________________
Greg M. (Gembone)
Member of the Nevada Chapter!
1970 F100 Flareside, 300 i6, 4-spd, 2wd
My Truck Thread
  #2 (permalink)
Old 01-08-2013, 11:14 AM
Gembone's Avatar
1970 Ford F-100
UPDATE: The only info I was able to find prior to today was to align the timing mark on the cam gear with the colored link in the secondary chain.
Originally I thought my chains didn't have the off-colored link but I gave them a good cleaning and managed to find those links. Yay for me!
My friend got the machine shop to also take a look and set them if my alignment is incorrect.
He will be taking the heads back by there today.
I will keep you updated if my timing was right or wrong.
Also thanks to SDV10 who posted the pick of the cam gear timing from the Navigator shop manual in his tech stuff album.
Will be very helpful for those that don't have the colored chain and can count links.
__________________
Greg M. (Gembone)
My Truck Thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
