speedometer cable removal? 78 ford bronco - Ford Truck Enthusiasts Forums
Old 12-23-2012, 10:52 AM
mrduke41 mrduke41 is offline
mrduke41 is starting off with a positive reputation.
Hello all,
I am trying to remove my cluster from the dash of my bronco. The speed cable is attached by a white clip. I can't get it disconected from the cluster and I don't want to break it. Can someone tell me how to disconect the speed cable from the back of the cluster. I am sure it has something to do with the white clip but im just not sure what to do with it. I would really appreciate some help. thnx, Duke
Old 12-23-2012, 11:07 AM
armstrongfordtrucks armstrongfordtrucks is online now
armstrongfordtrucks is gaining momentum as a positive member of FTE.
It's easy, (yea right) there is a plastic tab you can't see as it's to close to the dash. you just need to squeeze it in about the middle, them it will slide right out. Just keep squeezing in different places. It should slide out very easily, you won't need to force it, however they are easily broken.
Old 12-23-2012, 11:09 AM
thank you so much, I will give it a try. thnx, duke
Old 12-23-2012, 11:10 AM
If you go under search (TYPE speedometer removal, there is a picture)
Old 12-23-2012, 11:12 AM
<TABLE id=ncode_imageresizer_warning_1 class=ncode_imageresizer_warning width=400><TBODY><TR><TD class=td1 width=20></TD><TD class=td2 unselectable="on">Click this bar to view the full image.</TD></TR></TBODY></TABLE>
Old 12-24-2012, 12:06 PM
thanks again! i got it figured out
Speedo Cable Removal jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-19-2014 01:06 PM
Broken Speedo Cable Clip FordIowan 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-11-2012 08:46 PM
TROUBLE!!! Blower AC fan stays on!!! Please Help!!! dunerunner25 Excursion - King of SUVs 8 02-23-2009 08:07 AM
Speedo cable removal from speedo grey77 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-21-2005 08:24 AM
Speedo gauge makes 'scratching' noise in my 89... Mexray 1978 - 1996 Big Bronco 5 04-11-2002 02:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
