Questions regarding 2012 Flex TMPS - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 12-22-2012, 08:07 PM
Roger Carter's Avatar
Roger Carter Roger Carter is offline
Roger Carter is gaining momentum as a positive member of FTE.
I see where Ford went away from the band mounted tire pressure monitors and went to a valve stem mounted monitor in the 2010-2011 time frame.
Does anyone know if the earlier band mounted units will "talk" to a 2012 Flex?
From what research I have done it appears the newer units can replace the older ones but I haven't seen where the older monitors will work with a newer vehicle.
I have a set of winter treads with the band type sensors. I used this set-up for the last 3 years on our '09 Flex. We replaced the '09 with a '12 Flex earlier this year. I installed the winter tires and can't get the sensors to talk to the car. Went to my local dealer and they couldn't get the system to work properly, either. Their "tool" could sense the monitor, so I am fairly sure a bad battery isn't the problem.
I would prefer to not put out the $$$$ for a new set of monitors if I don't have to.
Any suggestions, other than a piece of black tape to cover the dash light, for a cure?
Thanks.
Roger Carter
tpms question crazy caper 1999 to 2016 Super Duty 5 12-30-2014 01:17 PM
Tire pressure monitor problems deputypq920 2009 - 2014 F150 17 12-28-2012 05:25 PM
valve stem vs. band TPS sensors RSCHAP1 1997-2006 Expedition & Navigator 4 06-08-2012 08:12 AM
Stand-alone MIL Eliminators fiftyfordfloored Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 10-30-2011 04:40 PM
Tire Pressure Monitoring System tcrowls 1999 to 2016 Super Duty 1 02-19-2010 08:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
