Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-22-2012, 07:33 PM
99hosss 99hosss is offline
1966 Ford F-250
99hosss is starting off with a positive reputation.
223/240 swap
Hello forum, hey, can I swap a 223 in place of my 240 which is bolted to a 4 spd T-98? The 223 is a 61 year, and the 240 is a 66 year. Merry Christmas to all
__________________
My addiction- wire brushing rust
  #2 (permalink)
Old 12-22-2012, 11:21 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
If I needed to replace a worn out 240, I would seriously consider a 300 cu in six. I think it's a direct replacement and there always seems to be one or two on CL. Not sure about the 223 being a bolt up. I guess it's just me, but I've always wanted a 300 six. My first truck ever was a 65 f 100 I bought in 1971 with a 240. I thought I was the king of the world!....
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #3 (permalink)
Old 12-23-2012, 06:51 AM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
As Gary said, a 300 would go in there easier. A 223 would take a few extra parts but if you already have all you need, throw it in there. i am a big fan of the 223!
  #4 (permalink)
Old 12-23-2012, 12:23 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
If you have a 240, why not get a 300 to build with the 240 head? My understanding is that gives you a higher compression ratio on a budget. That and some 1.6 rockers for the mild cam effect and it's an engine that goes good and will last a long time. Keep in mind this is just what I've gleaned from the interwebz
  #5 (permalink)
Old 12-23-2012, 01:35 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Quote:
No. This is not a bolt-in swap. The 223 has a different bell to block pattern. The T98 uses the old "square" trans to bell pattern. The 223 has the intake/exhaust on the driver side. The 240/300 has it on the passenger side.
Motor mounts may be different as well. I'm not sure, but it is possible the 223 uses a front mount and the side mounts are off the bell. You can check that easily enough. The 240/300 uses side mounts.
IF you want to swap, go with the 300 and a Mazda or ZF 5 speed. (serving suggestion)
Col. Flashman has a 300 in an older truck, if you are still interested in the project, he can be looked up and consulted. This isn't that big a change, but it's not quick turn of the wrench.
  #6 (permalink)
Old 12-24-2012, 08:18 AM
1966 Ford F-250
Thanks to all for the info, I just finished my 66, had it ready to drive in our local C-mas parade, and the week of the parade the crank spun a bearing. I have this complete 223 in the garage, just was hoping it would fit in for the winter- The 300 idea sounds like the way to go, Happy holidays to all
__________________
  #8 (permalink)
Old 12-26-2012, 02:48 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
FTE member Col Flashman swapped a 300 I-6 into his 1958 Mercury M100 that originally had a 223. Suggest you contact him for details.
He also swapped in Toyota P/S.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
