no low beam headlight - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-22-2012, 05:50 PM
aircropsinc aircropsinc is offline
aircropsinc is starting off with a positive reputation.
i have a 99F-450 with no low beam. Changed out Mult function switch, Headlight switch and bulbs, High beam works when MFS is pulled back. Fuses are good because when high beam is on i checked with test light, lights up but when low beams are on, no power to fuses. Any help would be nice
Old 12-22-2012, 09:03 PM
SC_Hoaty's Avatar
SC_Hoaty SC_Hoaty is offline
SC Chapter LDR
SC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputationSC_Hoaty has a superb reputation
Isn't there a relay in the headlight circuit? You didn't mention checking it. There is one place to look.
This thread has some other areas to check if the relay is OK.
http://www.ford-trucks.com/forums/10...t-working.html
Old 12-22-2012, 09:04 PM
SC_Hoaty's Avatar
SC Chapter LDR
And welcome to FTE!
Old 12-23-2012, 08:38 AM
I didn't see a relay, I looked at the manual and didn't see one. Checked both under the hood and under dash. thanks for the reply
Old 12-23-2012, 10:03 AM
SC_Hoaty's Avatar
SC Chapter LDR
I'm just guessing, since the 450 is different than the 150 and 250 I have.
I downloaded the owners manual for your year and model, and did not see any mention of a relay, except for daytime running lights. Do you have those? (Fuse 28, DRL relay coil).
Also, the low beams are on two separate fuses, as I'm sure you know. Numbers 9 and 11 in the power distribution box under the hood near the brake master cylinder.
Have you checked them for voltage when you want the low beams on? This may help figure out if the problem is before or after the fuse.
There are some wiring diagrams for the '02 F450 that are linked from this thread:
http://www.ford-trucks.com/forums/11...-location.html
Those diagrams make it look like the headlight fuses are downstream of the multifunction switch.
Old 12-23-2012, 11:29 AM
On hight beam the test light lights up but under low beam its dead, thats on both fuses. i blew up my volt meter so i haven't tested voltage. Im thinking between light switch and the fuses. Thank you so much for your help.
Old 12-23-2012, 12:12 PM
apparently I've been looking at this all wrong, I don't have high beams. Multi-function switch is in middle position, pull toward driver flash to pass, then push to ward engine high beam ( i don't have high beam indicator on cluster) so i may have the dims but not the brights. As to be something simple , but i can't see it yet.
Old 12-23-2012, 12:21 PM
Old 12-23-2012, 10:02 PM
SC_Hoaty's Avatar
SC Chapter LDR
Fuse 16 on the inside fuse box? I'm seeing it is a 15 amp fuse for the hi beams.
Old 12-23-2012, 10:03 PM
SC_Hoaty's Avatar
SC Chapter LDR
And does the flash to pass work OK? That would be a clue.
2007 Passenger side low beam problem mechasus Escape & Escape Hybrid 10 01-20-2017 09:36 AM
05 f250 headlights problem NEED HELP PLEASE! Lesalvato616 6.0L Power Stroke Diesel 3 02-17-2015 03:04 PM
06 F-250 High beams will not shut off 4INer 1999 to 2016 Super Duty 10 02-27-2014 08:27 AM
low beams wont work Rods 1977 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-18-2012 11:43 PM
High Beams Work, No Low Beams? Weezman 1978 - 1996 Big Bronco 4 09-09-2008 06:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
