Hutch mod - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Hutch mod
Old 12-22-2012, 12:45 PM
dmanshane's Avatar
dmanshane dmanshane is offline
dmanshane is starting off with a positive reputation.
Hutch mod
I am thinking on doing the hutch mod..... I start sucking air at about a 1/4 tank of diesel left? I do have a couple question what do you do to hook up the fuel lines to the top of the tank and the fuel pump since they are a quick disconnect type of deal more worried about the fuel pump side because on the fuel tank it looks like you can slip a piece of hose on the outlet of the tank
Old 12-22-2012, 12:50 PM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
The hose ends are attached the same ... push on and clamp tight. Pre pump is vacuum and that will help seal the hose.
Old 12-22-2012, 12:51 PM
dmanshane's Avatar
That's what I figured just wanted to make sure
Old 12-22-2012, 01:12 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Since I'm still running the stock fuel bowl I use this as a pre-pump filter.
Also available at Napa.
The fuel line connector at rear of pump is not the typical quick-connect. This is how to remove it from pump.
Don't forget the Harpoon Mod.
Old 12-22-2012, 01:36 PM
My 01 and my fathers' 02 were the typical QD spring fittings. Guess it depends on the year.
Old 12-22-2012, 01:40 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
It's the quick disconnects that were allowing air into my fuel. When the tank is full, gravity prevents a vacuum in the fuel line. Once the fuel gets low, vacuum can build in the fuel line and Quick Disconnects with O-ring seals... well... suck... at sealing a vacuum - so air gets in. I replaced my fuel line with injector tubing compatable with diesel (if you buy something inexpensive, it's likely going to dissolve and/or collapse) and injector hose clamps (better clamping on hose). Many people believe air is sucking into the fuel pickup tube at 1/4 tank and this may happen sometimes, but my experience showed everything in my tank was fine and the QDs got me. I'm still glad I dropped the tank to do the Harpoon mod, remove the mixing chamber and filters, and divert the return away from the pickup.
I got all fancy with my pre-pump filter, but ultimately went with the filter similar to the one above because my big injectors already tax the fuel system enough... without my sabotage.
Old 12-22-2012, 06:02 PM
Tailgate77478 Tailgate77478 is offline
Tailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud ofTailgate77478 has much to be proud of
if you're sucking air at 1/4 tank, you've likely got a broken pickup foot. You can order a new one from either Riff Raff or Diesel Orings. Or, if you do-it-yourself Hutch Mod parts...just buy a long enough steel tube to go down almost to the bottom of your tank. That's what I did...didn't realize the foot was broken until we had it down and open.
Old 12-22-2012, 06:21 PM
Bonanza35 Bonanza35 is online now
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Aren't you all using 3/8 line to the fuel pump. If so, are you just clamping the line onto the 5/16 inch filter as above? Or am I missing something. I do need to do mine as well. Maybe next tech day so I can get some help. Thanks,
Chet
Old 12-22-2012, 07:21 PM
jeffreyt's Avatar
jeffreyt jeffreyt is offline
jeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to beholdjeffreyt is a splendid one to behold
The pickup line on the top of the foot is 3/8. The fuel pump is 5/16. There are a couple ways people deal with this. One is to install a barb reducer to size down the hose. Then there is the crowd that double clamp at the tank side of the filter, size down on the pump side to 5/16. Then some who use screw on style filters can use whatever size barb fittings they need for the inlet and outlets. And then I know one guy who used compression barb fittings on the pickup line and pump, so he just got the right size barb and kept that size all the way through.
Old 12-22-2012, 08:04 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
I just went with this kit from Strictly Diesel,http://www.strictlydiesel.com/p-2662...-pump-kit.aspx they say you can build a kit yourself from scratch,but I like the one stop shopping thing. If the duck bill cracks like mine did you might run out at a quarter tank. The reason I went into my tank was I was running out of fuel at a quarter tank,and I was having power issues at high RPMs,come to find out my duck bill was cracked,my pick up foot was broken off,and my mixing screens looked like this...
And while I had it all apart..I modded my filler neck so I can fill up using the big nozzles at truckstops...
Old 12-23-2012, 07:22 AM
Poolguy601 Poolguy601 is offline
Poolguy601 is gaining momentum as a positive member of FTE.
If you dont install the small filter on the frame, wont the dirt just get stopped at the filter on the engine. Or are you tring to stop it before it gets to the electric pump.
Old 12-23-2012, 08:00 AM
jeffreyt's Avatar
Yes, it needs to be stopped before it gets to the pump. Let's back up and clarify. We aren't looking for a "filter," we want a strainer or screen. Just trying to grab the large chunks and particles to keep the pump safe. That is the purpose of the in-tank screens, but they are too difficult to service inside the tank. The second reason we are deleting the in-tank screens is to reroute the return line away from the pickup.
Old 12-23-2012, 08:24 AM
Joe28443's Avatar
Joe28443 Joe28443 is offline
Joe28443
Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.
I love this site!!!! The only time I let my ex get down to 1/4 tank I cut off going down the road. Now I know the duck bill is probably cracked. Can't wait to do that mod!
Old 12-23-2012, 11:14 AM
PaysonPSD's Avatar
Quote:
That's the reason for the pre-pump filter.
Old 12-23-2012, 11:55 AM
th67ss's Avatar
th67ss th67ss is offline
th67ss is gaining momentum as a positive member of FTE.
Is there any advantage or disadvantage to running the screw on type of filter/strainer vs the small type like Paysonpsd posted?
I really need to do this mod and it looks like the smaller type would help in the cost department.
No Hutch mod? Beware! ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 19 04-13-2015 02:20 PM
7.3 Sending Unit / Hutch mod?? Beechnut 1999 - 2003 7.3L Power Stroke Diesel 10 02-02-2014 12:05 AM
Air Bubbles After Hutch Mod Bigtruc 1999 - 2003 7.3L Power Stroke Diesel 12 01-01-2013 09:39 PM
Is the FRx mod needed with the Hutch mod? Chipworkz 1999 - 2003 7.3L Power Stroke Diesel 22 04-15-2012 03:59 PM
ITP Fuel tank Kit/ Hutch Mod dcara 1999 - 2003 7.3L Power Stroke Diesel 1 07-20-2009 06:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
