spark plugs - Ford Truck Enthusiasts Forums
spark plugs
Old 12-22-2012, 10:53 AM
theerod theerod is offline
theerod is starting off with a positive reputation.
spark plugs
I have a 77 F-250 with a 460. The spark plugs get carboned up fairly quick I was told to use a hotter plug Any suggestions?
Old 12-22-2012, 11:53 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
Maybe. I think I would find out why the carbon. Too rich? Burning oil?
Old 12-22-2012, 02:50 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Hotter plug may work but you need to do some troubleshooting to find out why the plugs are carboned up in the first place.
Like V10man said, it could be running rich (dry black carbon) or burning oil (oilly, crusty deposits).
Unless you find out why, then you're only treating the symptoms not curing the problem.
spark plugs for a 93 f250 5.8 waylen89 1987 - 1996 F150 & Larger F-Series Trucks 1 01-23-2016 06:35 PM
engine not firing zech Ranger & B-Series 1 09-18-2015 10:25 AM
Spark Plug Coils makthenif 1997 - 2003 F150 6 04-24-2014 09:49 AM
2008 Expedition emergencyehicle 5.4L. spark plug replacement Robert Gift 2007 - 2014 Expedition & Navigator 5 01-17-2014 06:52 AM
spark plug question RangerBlues Electrical Systems/Wiring 6 12-14-2006 11:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
