cummins conversion
Old 12-19-2012, 02:45 PM
backwoods72's Avatar
backwoods72
backwoods72 is offline
cummins conversion
ok newby here, and maybe this came up some time ago, i have not looked back too far, but has anyone done this conversion, i have a 1978 F250 crew cab w/ 460 C6 auto trans, wondering what is all envolved in the conversion to a 12V cummins, i live in alaska so i know the cost will be more then you fellas in the lower paid to have this done , but just wondering.
thanks
Old 12-19-2012, 02:56 PM
vic_v8's Avatar
vic_v8
vic_v8 is offline
yes, done many times, I can't remember the user on here, but it has a built thread. Also look at the 4btswaps.com page and google fummins
Old 12-19-2012, 03:11 PM
backwoods72
right on thanks i will look for it
Old 12-19-2012, 08:13 PM
crrnchris's Avatar
crrnchris
crrnchris is offline
Old 12-19-2012, 08:15 PM
asweetroy's Avatar
asweetroy
asweetroy is offline
P pump or stay home on all cummins swaps
Old 12-19-2012, 09:49 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Ya, 400+ horsepower out of a rotary VE pump just doesn't cut the mustard.
Old 12-20-2012, 11:46 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
Lots of cummins swaps going on down in the "motor swap" forum on here including mine.
Old 12-22-2012, 02:08 PM
jimlj's Avatar
jimlj
jimlj is offline
thanks
Is your truck a 2 wheel drive? If so I have heard there is a problem with oil pan and steering linkage. You may be able to find a pan that won't get in the way.
If you have a 4X4, you have to cut about half of the front cross member out and box it back in. You will have to fab your own motor mounts, transmission mount, lengthen front and shorten rear drive lines.... Don't get me started.
If you can fab/weld/visualize, and look on line at others pictures and description of how they did their swap, it is not that hard, and at least for me a good diversion from the job that puts food on the table.
lalberts
02-12-2018 01:22 PM
zigzkidz
General Diesel Discussion
03-31-2007 05:10 PM
Quick Reply: cummins conversion
