need motor mount school 53 f100 239
I'm having my 239 flathead overhauled and this seemed like a good time to re-do the motor mounts. I've got the "1948 - 1956 Forf Truck Parts and Accessories Illustrated Catalog". I can't seem to find the 1953 239 front motor mounts. I see several other v8's just not the 239.
My second question has to do with how much of the mount is usually replaced? For the rear I see castle nut bolt bushing and a couple of pads.
Do you just replace the pads unlesss something is totally worn out?
Thanks
Thanks
Dennis Carpenter has them:
http://www.parts123.com/parts123/yb....Z5Z5Z50000024C
Just replace this part, unless something is broken.
The rear mounts have two pieces. There is a small rectangular piece that goes under/inside the cross member, and a larger piece that fits over/around it. You need to replace both pieces on each side to do it right.
Last edited by EffieTrucker; 12-22-2012 at 09:17 AM. Reason: Added note abount rear mounts.
revamp1953f100
04-27-2017 08:25 AM
DoubleO7
07-08-2008 11:36 PM
alabbasi
10-05-2006 01:33 PM
darkman
04-24-2001 11:00 PM
