Door Glass Replacement
I need to replace the passenger side window in my F-250 (glass is shattered). I have the new glass and new weatherstripping while I am at it.
I have 2 manuals which give a fair description of the procedure but both mention the need for a special tool to install the new glass into the lifter channel. I see no mention of it in the few threads that I found. Is that really necessary or is there a way around it?
Any advice or links to threads I may not have found would be good.
The window is "Glued" in place...
So maybe that is the reason...
The manuals make no reference to the window being glued in, just the need for some type of tool. You would think that they would reference the glue for re-installation if it was glued in.
I know that GMs use some kind of tape in the channel because I have a friend who has worked on lots of GM trucks.
Hope I haven't gotten in over my head (money-wise) by needing to purchase a special tool for one window.
Removing the glass from the door makes replacing the window channel rubber a much easier task, and that can be done with just a few simple hand tools.
Essentially it will spread it out a bit for it to slide in to the channel. I have seen on occasion where the glass had come out of the channel. You might get it to push in once the glass is in the door. Otherwise it will be hard to know how to get it positioned. You might take it and the channel to a glass shop and have them help you.
MO51
02-11-2008 11:41 AM
azls1
07-18-2007 11:42 PM
