no throttle response..
I have a 2005 F350 diesel, 54000 miles. I was at a red light today, engine is idling normaly.. light turns green and I step on the throttle and get nothing. My truck is rolling (in drive) as if it were in nuetral. I shut the engine off and it does not start for 10 to 15 min. Then it fires up and seems to be running as if nothing happened. Anyone have the same experience?
<!-- / message -->
<!-- / message -->
I had my Tow/Haul wire replaced, the transmission had a mind of its own, doubt if that would cause a No Start. Do you have any other related No Start when Hot or is this your first...incident? Pointing toward the high pressure Snap to Connect fitting.
One other concern, we are working with a perfectly stock truck?
I had a similar problem. Would start cold idle, push accelerator...nothing, injectors would go quiet until I let off. After engine started warming up, IPR % would start to climb until it max'd out @ 83 %. IPC would drop to 450 then wouldnt restart till after it cooled some. Failing HPOP was the cause. Oh, and if I did hold the pedal down it would push black smoke also. If your fuel pressure and pedal are ok, then I would start looking for a HPO leak somewhere.
KarmicAflixion
1999 to 2016 Super Duty
09-28-2017 09:20 AM
