Go Back   Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Sign in using an external account
Register Forgot Password?
Old 12-22-2012, 01:39 AM
gene daniels gene daniels is offline
gene daniels is starting off with a positive reputation.
ILLUMINATED ENTRY DOME LIGHT
2008 E250 - How do we turn the illuminated entry off/on ?
Problem is the Omega alarm needs the dome light activation to activate with all doors. I am assuming that is true from continuous trial and error.
With the illuminated entry off, I only get the driver's door to activate the alarm thru the door ajar switches. And if the rear door light - bulb was removed to save batt power - is grounded then the rear door ajar switch signals the alarm.
No wire inside the passengers door wire run or the 'correct' beige wire at the kick panel control box will activate passenger;s door or cargo door door ajar alarm signal circuit.
Instructions herein indicate the remote key fob unit turn Illuminated entry off/on but not how to do that.
Similar Threads
Weird problem with 02' F350 v10minator Super Duty & Heavy Duty 6 09-03-2011 01:13 PM
Door Ajar Swith or Actuator? WhiteBeast97 1997 - 2003 F150 3 01-13-2007 08:18 PM
Door Ajar alarm PatG Ranger & B-Series 7 10-19-2004 02:18 PM
disabling door handle - dome light circuit stoad Explorer, Sport Trac, Mountaineer & Aviator 1 02-16-2004 11:03 PM
Door ajar Gcourville Super Duty & Heavy Duty 4 01-02-2004 07:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
