5.4 misfire - Ford Truck Enthusiasts Forums
5.4 misfire
Old 12-21-2012, 10:54 PM
RLGJ RLGJ is offline
RLGJ is starting off with a positive reputation.
5.4 misfire
Hi, I have a 1999 F-150 4x4 with the 5.4. It was missing bad and had misfire on #2 and #3. Found bad injector on 2 and bad coil on 3 replaced them and plugs and miss went away. Its running good but about every 100 or so mile light comes on and I have code 303 and 171, misfire on #3 and lean on bank 1. Can't find anything wrong, thinking injector. Any input would be appreciated. Thanks in advance.
Old 12-22-2012, 12:23 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
most missfires are due to COPS... even if you just installed one.
code 171 is normally vacuum hose leaking, or intake manifold gasket leaking. Look for hard or cracked vacuum hoses. The two small ones on the EGR above drivers valve cover is a good place to start.
Old 12-22-2012, 01:22 AM
Thanks for the info. Will look for vacuum leak tomorrow. Let you know what I find.
Merry Christmas
Old 12-22-2012, 06:45 PM
Looked for vacuum leak but never found one, a few of the hoses look suspect old and brittle looking but no leak found. tried listening for leak with a stethoscope definitely no big leak. Would a small leak cause problem and what's the best way to locate?
Truck has about 100 miles on it since last code if it does it again I will swap cop with another cylinder and see if misfire follows and try to find better way to locate vacuum leak.
Old 12-26-2012, 07:14 AM
hookedondiesel hookedondiesel is offline
hookedondiesel is gaining momentum as a positive member of FTE.
I've heard some use a propane torch to find vacuum leaks.
Turn the torch on lightly, DO NOT LIGHT IT, and go over your hose's
and listen for the engine to respond,
Listen for a change in your engine’s idling. The idling should change immediately after you pass over a leak with the tip of the propane torch. The reason the idling changes is because the engine will suck in the propane through the leak, providing the engine with more fuel.
Old 12-26-2012, 12:17 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Clear the missfire first.
Swap coil with another location to see if the missfire follows.
Don't run with a missfire because the cats are put in danger if raw fuel passes through and burns in the cats.
After misssfire is cleared, clear codes to see what comes back.
Then go after that code.
Good luck.
Old 12-26-2012, 07:19 PM
Thanks for the response. Haven,t had time to work on it due to holidays. Will get back at it next week and let you know what I find. Thanks again hope yal had great Christmas.
Old 12-29-2012, 11:47 PM
swapped coils from #1 and #3 today and cleared codes, will see if I get misfire on #1 now instead of #3. Also looked for vacuum leak again. Didn't find any leaking hoses but found bad cpv valve. Will replace it as soon as I can get one and see if that fixes the bank 1 lean code. Will update again with results. Thanks for the responses.
Old 12-30-2012, 12:33 PM
vfast vfast is offline
vfast is starting off with a positive reputation.
leaking manifold gasket
soon it will start over heating
Old 01-01-2013, 07:00 AM
Vfast, hope that's not he case but might be. After replacing CPV valve and swapping cop on #1 and #3 I cleared codes. After a little over 100 miles cel came back on, checked codes and got 171 again but no 301 this time. Going to try and rig up a homemade smoke machine to check for vacuum leak. Have tried carb. cleaner and propane with no luck. The old CPV valve still rattled but I could blow through it both ways with no resistance, the new one( from autzone) I can also blow through it both ways, it does have some resistance one way but doesn't seal off, is this correct or could that be my problem? Thanks again for all responses and Happy New Year!!!!!
Old 01-01-2013, 01:20 PM
see if under oil cap is milkey
Old 01-01-2013, 03:21 PM
Not milky under gas cap. Got smoke machine going and found a vacuum leak. It was on the very back of intake toward firewall. There is some kind of sensor mounted to back of intake, has 2 bolt flange mounting it to intake, right beneath that there is a 3/4" hose barb coming out of intake, this is the hose that was leaking. This hose reduced down to 1/4" and ran down firewall and back across passenger side valve cover and was plugged off. Can you tell me what this hose was supposed to go to, wondering what previous owner removed? I removed broken hose and plugged it off, smoke tested again and found no leaks, reset codes. Will update once I drive and see if codes comeback. Thanks for all the input. Really curious to know what that hose originally went to.
Old 01-01-2013, 03:40 PM
I found a pic. of hose routing on another post and it looked like the hose I'm talking about connected to a tee that went on the cpv valve and to intake. Is this correct and if so do I need to get a new hose and tee and connect this or leave it plugged off? Thanks again for any input
Old 01-02-2013, 09:31 AM
Been home and back to work about 90 mile round trip and no cel yet, hopefully that vacuum leak was the problem. And thinking maybe it was the connector on my #3 cop causing misfire. Time will tell. On the vacuum routing diagram on truck (partially missing) it looks like that vacuum line originally went to a canister that also had a vent line from gas tank. Canster is not there, haven't got underneath and looked for vent from tank yet. Does this sound correct and is it needed?
Old 01-03-2013, 07:45 AM
Thanks
Just wanted to say thanks to those that replied. Truck has been driven over 150 miles now and still no cel and it definitely idles smoother. Glad I found this site, found several fixes by reading older posts, has saved me lots of time and money already.
Thanks again
Replacing fuel injector ExcursionXLTjordan Excursion - King of SUVs 5 10-27-2016 10:28 AM
NEED HELP PLEASE: 2004 F150 XLT 5.4l (3v) misfire kulla 2004 - 2008 F150 4 12-14-2014 10:56 AM
2009 f250 5.4l misfire chefy30 1999 to 2016 Super Duty 9 12-13-2013 09:44 AM
misfire #1 cylinder and injector ? strokin72 1997-2006 Expedition & Navigator 2 02-28-2006 05:41 PM
misfire nallen731 Modular V8 (4.6L, 5.4L) 13 10-16-2005 01:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
