rebuild or not?
rebuild or not?
Long story short.
Start truck cold, getting clicking noise...sounds like valve but runs great. Warms up and clicking goes away. Remove #1 spark plug and it shows build up of whiteish carbon. Will remove the other spark plugs and check. Also starting to use half a can of oil a week. No leaks that I can see. Oil pressure gage shows high...always has. Also, open door and get out after driving and smell oil. Wanted to make it to 400k but might not be able to with this issue.
Going to do a compression check to see what else is happening.
Still have decent power.
If cylinder pressure is good would it make since to do just a "top end" rebuild (if it is a valve issue?
Should i pull it and do a complete rebuild?
What does white build up on spark plug usally indicate?
Original owner
thanks
Original owner
thanks
Long story short.
Original owner
thanks
Original owner
thanks
Put a real mechanical gauge on it
to check the oil pressure.If you haven't all ready done so.
And go from there.
willyd520
13
05-17-2019 07:09 PM
Vegas123
10-02-2015 07:43 AM
sportfuryjoe
01-20-2011 06:34 PM
myeverett
11-19-2002 06:11 PM
