door ajar indictator please help! - Ford Truck Enthusiasts Forums
Old 12-21-2012, 05:14 PM
newbie_to_trucks newbie_to_trucks is offline
newbie_to_trucks is starting off with a positive reputation.
when i bough the car i went on a test drive and everything was fine, once i bough it and went home my fiance opened the passanger side door to get in, and every sense than the door ajar light is on and the inside lights will never turn off and its draining down the battery, we have tried slamming the door shut and we just dont know what to do, theres not even a sensor botton to check out theres no way to tell what it could be for me as when i open the door to check out the botton like most vehicles do, there isnt one, what could it be? please help going thru batteries quickly!
Old 12-21-2012, 05:18 PM
vaper vaper is offline
vaper is starting off with a positive reputation.
The switch is in the door.
Spray some lubricant into the latch/jaw assembly
Old 12-21-2012, 06:00 PM
like internaly? where the actual locking mech is at? spray into that?
Old 12-21-2012, 06:55 PM
Yes the latch mechanism on the rear edge of the door.
Spray in and around it.
Common problem with these trucks
Old 12-21-2012, 10:11 PM
it didnt seem to work, is it an over time thing?
Old 12-22-2012, 09:41 AM
Old 12-25-2012, 05:49 AM
KEEPGDTRKSRNNG's Avatar
KEEPGDTRKSRNNG KEEPGDTRKSRNNG is offline
KEEPGDTRKSRNNG is starting off with a positive reputation.
The door latch and jaw assembly, I call it anyway, WD40 can with a straw and stick it in and around every nook and cranty of that thing and just spray the heck out of it.
Old 12-25-2012, 01:53 PM
Spotty Spotty is offline
Spotty is gaining momentum as a positive member of FTE.
Don't overlook the fact that it may be the OTHER door. Spray both of them down real good then open and shut them about 15 times....it'll work. Stick with the WD #40 at this point so you don't ruin your paint or such using "who knows what". Even if the switch fails, I know on my truck after like 30 minutes it times out and they go out regardless....( Built in safety so battery won't get drained completely).
Old 12-25-2012, 02:16 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
One ck .If you put the key in with the door closed and the dinger goes off , it is your driver door switch . The switch cams into the latch . It can be changed ,or unplugged . You have to remove the door panel to acces . They are a booger to change with the latch still on the truck .
Old 03-09-2013, 09:27 AM
RLICHT RLICHT is offline
RLICHT is starting off with a positive reputation.
I was having the same problem ... door ajar ... with all door securly closed. It was driving me crazy. I came across this web site and discussion others were having about the problem. A few sqirts of WD40 in each door lock and presto, no more problem. So I decided to join the forum and share some of the other issues I've encountered thay may help others.
Help with dome light please. chritter 1999 - 2003 7.3L Power Stroke Diesel 14 11-14-2013 07:31 PM
Door ajar problem...help! nlemerise 1999 - 2003 7.3L Power Stroke Diesel 13 04-14-2012 01:33 PM
Problem with 93 F-150 4wd Doxy Clutch, Transmission, Differential, Axle & Transfer Case 1 09-14-2009 12:57 PM
Door Ajar Light on Dash 2002 X Excursion - King of SUVs 15 05-27-2009 08:48 PM
Door Ajar Light And Doom Light SWGROUP 1997 - 2003 F150 7 02-09-2003 06:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
