Clutch line
Old 11-20-2012, 09:54 AM
K9sicem's Avatar
K9sicem
K9sicem is offline
Clutch line
I forgot the most important part in my last post. Where can I find the hose that goes from the master clutch to the slave. I have check many parts catalogs and have not found one. It there a name other then clutch line that I am missing?
Scott
Old 11-20-2012, 10:08 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Scott; first off welcome to the orphanage!
If you have the old one you can take it to NAPA or some other parts dealer and find a close match. This hydraulic line has been discussed here before and at that time there was only 3 NOS line found and no one remakes a direct replacement. Some have replaced theirs with hard line adding a couple loops for flexibility.
Good luck in your quest.
Old 11-20-2012, 11:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B7TZ-7A512-A .. Tube-Clutch Master Cylinder to Slave Cylinder / 1957/60 F100/950 / Obsolete
ONE available NOS / OP: You want the source? Send me an email sylhall@aol.com
If I post the source here, tube will gone in a NY minute. And activate your P/M and email features.
Old 11-20-2012, 12:55 PM
K9sicem's Avatar
K9sicem
K9sicem is offline
Email sent.
Old 11-21-2012, 02:30 AM
NumberDummy
Email received, responded to, source/phone number passed along.
Old 11-21-2012, 05:39 AM
rocdril's Avatar
rocdril
rocdril is offline
Bill, if thats the same one you sent me, it was never found. I spoke with the parts dept. several times. They showed it in the computer, but could not find it on any shelves.
Old 11-21-2012, 06:40 AM
NumberDummy
There were three available at one time, now there's only in AR / Dealers webpage updated 11/14/2012.
If this dealer couldn't find it, I wish you had let me know. I would have called, asked them to remove it from Ford Dealer Parts Locator System.
Several other members have contacted me, saying if OP didn't respond within a certain length of time, would I pass along the info.
Old 11-21-2012, 06:47 AM
rocdril's Avatar
rocdril
rocdril is offline
Yes, thats the one. I guess I should have let you know, to be honest I have been hoping for a call. They said if they found it I would be notified.
Old 11-21-2012, 10:37 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
I made mine from off the shelf NAPA brake lines and a Double female brake hose that they had to order. I think the hose was about 9" long. Looks pretty much like the original, works perfectly.
Old 12-01-2012, 01:53 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Do you have a local place that can make one? I'm in the same predicament. But I have a place nearby called , House of Hose that can make one, but I have an original for them to work with
Old 12-01-2012, 09:57 PM
chetspencer's Avatar
chetspencer
chetspencer is offline
I just bought parts from NAPA like Mr. Sisson above. Came out perfect. Better than original actually, as I can replace just the hose if it ever fails. I used DOT5 btw and it's working great.
Old 12-02-2012, 10:08 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Double female hose sounds like a winner. I may make a bracket on the firewall to mount the union.
Old 12-20-2012, 01:03 PM
crlydave's Avatar
crlydave
crlydave is offline
clutch line
believe it or not i used a steel braided front brake line from a polaris atv,worked perfectly!
Old 12-20-2012, 02:17 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
ORLY? Any other particulars, like year, we need to know? If not I'm gonna git one raht now.
Something like this?
http://www.ebay.com/itm/2003-Polaris...23256a&vxp=mtr
Old 12-20-2012, 02:25 PM
theodore/teddy
Refyred
I'm thinking those would be metric?
Quick Reply: Clutch line
