F250 - tire size for cabover? - Ford Truck Enthusiasts Forums
Old 12-21-2012, 12:20 AM
alvald83 alvald83 is offline
alvald83 is starting off with a positive reputation.
I just picked up a set of Aluminum wheels from a 1988 F250SD, with
LT 235/85 R16 tires on them. Will these work on my truck? Since i am carrying a cabover camper will these handle the weight?. and finally, What would be a good size tire to run with a cabover?.
I am currently running 9.5 X 16.5 and like the size - What is the equivelent present day size.
Old 12-21-2012, 02:31 PM
Able Dog Able Dog is offline
Able Dog is starting off with a positive reputation.
If my memory is correct, that tires max weight is 3025 lbs when inflated to max air pressure (80 PSI). Have you weighed your truck to see what your actual axle weights are?
In addition to axle weights don't forget about your trucks MVWR. Good luck.
Old 12-23-2012, 09:22 AM
Alex from GA Alex from GA is offline
Alex from GA is starting off with a positive reputation.
They'll be fine for the weight. Do you have sway bars? If not you might look into them. It was, by far, the best mod I ever did on my truck with a cabover camper. The 235 16s are taller than the 9.50s and have a higher load. They're load range E right?
Old 12-23-2012, 11:43 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
I had the white steel spoke wheels on 15x11 with 32" tires on my rig and the rims kept cracking the rears, they were good for about 5-6 yrs. Then bought some new Eagle Alloys 16x7.5" eagle rims that were rated for like 3400 lbs with Lt 265 D=32"-+ tires to handle the weight of the camper. You may want to find your rim online and see what it's weight rating is. for your peace of mind! my 2cents ..orich
1959 f100 cabover camper. Justo707 1957 - 1960 F100 & Larger F-Series Trucks 0 04-28-2015 12:58 AM
What size cabover camper? forager 1967 - 1972 F-100 & Larger F-Series Trucks 12 07-02-2012 10:57 PM
'69 f250 camper special - ready for cabover? alvald83 1967 - 1972 F-100 & Larger F-Series Trucks 2 06-05-2012 01:30 PM
Cab-Over Camper Needs idea man 6.7L Power Stroke Diesel 14 05-11-2011 08:09 PM
Cabover Camper zootown Montana Chapter 2 07-29-2010 01:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
