Exhaust Leak Detector
Old 12-20-2012, 09:01 PM
landmobile's Avatar
landmobile
landmobile is offline
I've suspected leaking up pipes for a while, but was never 100% sure. It sounded like there was an exhaust leak somewhere, but I only saw a little soot and my boost wasn't terrible (16 psi @ WOT). It was hard to get a good look behind the turbo, and feeling around for exhaust leaks behind a running 7.3 wasn't for me, so I built this:
It's basically the same as a boost leak detector, but pressurizes the exhaust system instead. I couldn't find anything in the plumbing aisle at Home Depot that fit my exhaust just right, so I used a neoprene 4 inch to 3 inch soil pipe coupler. The tapered part will seal a tail pipe from about 4 1/4 down to 3 1/2 inches, although it needs a helper to keep the fit tight.
Turns out my passenger side up pipe is leaking like a sieve at the collector, so bellowed pipes will be installed in the near future. The transmission needs to come out for the new flexplate anyway, so I'll probably do them both at the same time.
Chris
Old 12-20-2012, 09:21 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Nice job on making that - Gotta make myself one of those, just to make sure.
Old 12-20-2012, 10:29 PM
snakedoc's Avatar
snakedoc
snakedoc is offline
nice to bad i have a 4" exhaust that is bolted together.
Old 12-20-2012, 11:14 PM
MTDewX's Avatar
MTDewX
MTDewX is offline
I recently rebuilt the turbo, pedestal with new plenum inserts and boots. I romp on it and its lagging. I know the up pipes are leaking from start up from installing all the new goodies and exhaust flowing.
does the up pipe leak really rob that much power?
I took it out on the free way and romped on it sure took a long time to get up and go. I know its a van so its detuned with a big wind sale on top, but was sad.
up pipes are on the list, but was surprised it sucked that bad.
Old 12-20-2012, 11:51 PM
bakerbuilttracks's Avatar
bakerbuilttracks
bakerbuilttracks is offline
Chris looks great and excellent thinking. My exhaust is bolt on MBRP i wonder how it would work on that ? I have one clamp after my muff del that i can see a bit of soot around and don't know if the entire system "exhaust turbo back" would leak causing a miss reading. Also id have to get the 6" adapter for my tip lol. I also am suspecting a up pipe leak and am curious if this would work on my bolt on stuff.
Old 12-21-2012, 06:43 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
Guys I'd say if you kept a constant pressure on it, say regulated to 10 psi, then even if you're losing air at the bolt on connections, you can still spray the soapy water at the uppies to see of there's air coming out. I'd say check it cold with soapy water, check it hot by just listening for air (which is tough to do with a compressor running so a big tank would be necessary.)
Great idea on the leak detector though!
Old 12-21-2012, 08:37 AM
bakerbuilttracks
Jeff, thats what i was thinking keeping steady pressure and using soapy water. Panama City huh thats bout a 1.5 hr trip, nice to see a active member close to me. I think i got 1 other member here in Tallahassee.
Old 12-21-2012, 09:33 AM
joeyd61's Avatar
joeyd61
joeyd61 is offline
a friend of mine has a smoke machine. Stuck it in one of my stacks stuffed rags around it and in the other stack. Could see every leak and thats with a bolt together exhaust..
Old 12-21-2012, 09:35 AM
jeffreyt's Avatar
jeffreyt
jeffreyt is offline
There's myself and AzPete here in PC, and Smokiesman is here till the 1st. Robbragiel will be here a few days in January, and MTalley as well.
Old 12-21-2012, 01:28 PM
landmobile's Avatar
landmobile
I was going to use soapy water at first, but the leak was so bad that it wouldn't hold even a few psi. Fortunately, I could hear the air escaping.
Thought about using a smoke machine as well. We have one in the fire department for training, but using it to fix my truck probably wouldn't be such a great idea.
Don't know for sure how much power I'm losing since the leak has been there since I bought the truck. I'll post how I make out, but probably won't get to it till the first week in January.
Chris
Old 12-21-2012, 03:16 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I just use and infrared camera... doesnt everyone?
exhaust manifold:
Old 12-21-2012, 06:10 PM
srteach's Avatar
srteach
srteach is offline
Originally Posted by bakerbuilttracks
... My exhaust is bolt on MBRP i wonder how it would work on that ? I have one clamp after my muff del that i can see a bit of soot around and don't know if the entire system "exhaust turbo back" would leak causing a miss reading. Also id have to get the 6" adapter for my tip lol. I also am suspecting a up pipe leak and am curious if this would work on my bolt on stuff.
If you have a leak after the turbo, it will not rob power. It will make a mess with the soot, though.
There are no factory pressure sensors after the turbo in the 00-03 models. The only sensor that may be there is an aftermarket EGT probe.
The main power loss issue is header / up-pipes / collector leaking (all pre-turbine). That is the area that drives the compressor side of the turbo. If you lose exhaust there, you get lower boost pressures in the IC pipes (if you have them) and intake.
TimmyG
10-09-2010 01:49 PM
RAMPAGE_F350
03-30-2008 08:29 PM
George M
05-08-2007 07:12 PM
ncfirefighter46
01-14-2007 09:07 AM
DiamondDog
1997 - 2003 F150
12-30-2001 10:07 PM
Quick Reply: Exhaust Leak Detector
