1948 F47 sheet metal update
Thought I would share another update of my sheet metal work.
The right floor pan is in, and toe board patched.
Cowl patch tacked in place, and I had to make a lower 'cap'.
The kick panel and lower cab corner needed patches as well.
Also had to fix the seat/under floor re-inforcements, as the right side was worn badly.
Very nice work! Do you have a sheet metal brake? Those are clean bends.
For the door post repair, on the cap that seals the bottom; there was a flap kind of drain on the stock piece to let water that leaked past the windshield out. Don't weld it up solid, looks like water could get out at the corners.
Thanks. The bends were a combination of vise, anvil and pliers.
When I fabbed the lower 'cap', I did leave small gaps for drainage. The original was mostly gone, so I couldnt tell for sure, but I figured there should be drainage.
This is the template I made from the remainder of the cap pieces. I will just reverse it for the other side. (its not exact, but a little tweaking afterwards worked pretty well.
I am going to make mine like the original ones. A three sided square tab cut to let water out. The tab opening dumps to the rear of the truck to allow a draft to help pull moisture out while driving. I wonder how well that really worked, but the idea is pretty cool. On mine there was alot of buildup down in there, and thats where my concern is. I left it open for now, but need to get that done eventually. Nice work!
I suppose over time, if enough stuff were to get in there, it could clog, but it is only open to the inside of the cab, so 'theoretically' it should be OK. I tried to make it as close to original, and used 18ga (probably overkill 20 should suffice)
here is the left one, tweaked and ready to get some holes drilled for plug welds.
blue351
01-07-2019 07:41 PM
F-1
03-20-2017 05:18 PM
xtal_01
17
12-11-2016 04:02 AM
axman_F250
10-12-2011 08:07 PM
