Conflicking window sticker, build sheet
Wondering if anyone else has run into this or has an explanation. I ordered what I'm calling a build sheet, I've forgotten what it's actually called but I believe I paid 30.00 bucks for it from Ford Customer Service Division and gave then my vin number and they sent me this sheet. It decodes the vin # and goes on to list the optional equipment which states that my truck has fog lamps which it does not. Also it states that I have 17" wheels but in fact I have 18" wheels, A/V Jack, DVD Entertainment System which I have neither.
Then I found a link where I could put in my vin # and get the window sticker so I did that too. On the sticker as standard exterior equipment it list Locking Removable Tailgate W/Lift Assist. Well I do have a Locking Removable Tailgate but nothing that I'd call a Lift Asisst.
Under Functional equipment it list Power Windows/Locks/Mirrors, well I do have Power Windows and Locks but no power mirrors. The mirrors are heated but I don't think that is the same thing.
Love my truck but can't help but wonder why these differences, I looked as closely as I could and the fog lamps don't seem to have ever been on there and the headlight switch has no position for them and the same for the mirrors. I suppose the wheels could have been upgraded to 18" since the speedometer is a few mph's slow, something like registering 60 mph when actual speed via GPS is around 63 mph.
The power mirrors are for the extend and maybe the fold, right? I think it is built into the mirror adjust switch on the vehicles that have it.
My window sticker lists "TELESCPNG TT MIRR-POWR/HTD" but mine don't have the power extend or fold - just power heat. The extend is manual. (also no cost on that line.) I think the tailgate lift assist is a torsion spring to make it easier (not by much!) to lift the tailgate. Since I have a slide-in camper, the tailgate is currently off my truck or I would try to estimate the lift force required.
No idea on the fog lamps, however.
Regarding the fog lamps - check this out:
Which switch is mounted on your dash?
I have the center or middle headlight switch. no indication of fog lamps on the switch...and yes i did get the oasis report the other day and it only showed a couple of check engine light occurances where they replaced something about the injectors or something minor...I used a site where you consult a ford mechanic and he said that the truck looked solid and no major problems... I'm fine with the mirror situation except everytime I unhook from the trailer I drive off with them still extended and have to pull over and shove them in and of course the reverse is true, I hookup and pull over and extend them too... lol
akamacgyver
33
06-14-2016 06:00 AM
ufvj217
1999 to 2016 Super Duty
04-17-2016 06:02 AM
