difference between 5.0L and 3.5L Ecoboost - Ford Truck Enthusiasts Forums
Old 12-20-2012, 03:36 PM
4trapr 4trapr is offline
4trapr is starting off with a positive reputation.
It sounds like the only practical difference is for towing. What exactly is the difference? Why is the Ecoboost better for towing? How can a 3.5L v6 tow better than a 5.0L v8? I usually tow a boat from the WI/IL line to northern MN each summer. Is that enough reason to go with an Ecoboost?
Old 12-20-2012, 04:07 PM
mpally mpally is offline
mpally is starting off with a positive reputation.
How much weight are you towing? Personally, I don't think there is much difference between the two. However, I don't tow on a regular basis. If you're towing a small boat, then I think either will do the job just fine. I think the gas mileage between the two is minmial at best.
Old 12-20-2012, 05:27 PM
02transam 02transam is offline
02transam is gaining momentum as a positive member of FTE.
The ecoboost makes more torque sooner.
Old 12-20-2012, 05:34 PM
seventyseven250's Avatar
seventyseven250 seventyseven250 is offline
seventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud ofseventyseven250 has much to be proud of
Quote:
Yep, that's why it's better for towing. In theory, under unloaded conditions, the turbo V6 should get better mileage, but some owners are getting less than expected.
Myself, I'd buy it for the torque, not for the gas mileage.
Old 12-20-2012, 08:05 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
ecoboost twin turbo v6- lighter, higher torque rating, flatter torque curve, about 2-3mpg better combined average, and a tuner away from an extra 50hp 100ft/lbs torque (dont say turbos add complications to break all those big diesels you see in dump trucks to semis are TURBO diesels as are most all modern diesels).
5.0- most advanced v8 ford has made solid naturally aspirated type motor strong and good mpg makes plenty of power to do most you would want to do with an F150
Old 12-20-2012, 08:55 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Well said. The boost just makes more power over a broader powerband
Old 12-21-2012, 12:08 AM
Most people are not seeing a 2-3 mpg increase over the 5.0. I'd say is a wash, maybe 1 mpg. There is not enough difference to make mpg a deciding factor in my opinion.
Old 12-21-2012, 06:07 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
When I was shopping for trucks, I had my heart set on a 5.0L 4x4 with 3.55 axles. Drove one and smiled like a kid in a toy store.
The dealer pulled my truck up next to it and apparently he was having some real issues selling an ecoboost 4x4 with 3.31 axles. I drove it and I liked it the same. He made me a deal that I couldn't refuse.
In truth, the 3.7L trucks are more truck than most of us will ever need. Of course you can't get the 3.7L on higher end models.
I haven't heard of one reliability issue or chronic MPG with the 3.7L. If you're shopping for a lower tier model truck such as an XLT 4x2 or lower model, give it a look.
Old 12-21-2012, 07:39 AM
thiggins01 thiggins01 is offline
thiggins01 is starting off with a positive reputation.
I'm a V8 guy, and love the sound of my 5.0. I also tow our camper with it, and it does a great job. Very happy with it. We also get between 17 and 19 mpg not towing.
2016 vs. 2017 F150 EcoBoost Troy Buenger 2015+ F150 19 09-06-2016 11:38 PM
Gear ratio with 3.5L Ecoboost boss1982 2009 - 2014 F150 13 03-25-2015 09:56 AM
Final HP/TQ, towing, and payload #'s are up. 03 SVT VERT 2015+ F150 10 10-02-2014 12:23 AM
5.0 V-8 doesn't offer the Tow Max package superdutylee 2009 - 2014 F150 24 02-05-2013 05:41 PM
2011 5.0L and Ecoboost Dyno Charts (Both Very Impressive)! 640 CI Aluminum FORD 2009 - 2014 F150 46 04-14-2011 10:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
