Wiring a truck questions.
I'm going to buy a new aftermarket wire harness for my 56 F100. Now there is a lot of choices out there, brand, number of circuits, and where is test place to mount it. I'm going to run a 4.6 DOHC, A/C, power windows, probably electric fan, electric fuel pump in the tank and put it behind the rear axle. So is there a "better" brand, how many circuits do I need to get? Whats the best place to mount it? behind/under the seat? I know a lot of you guys have already been down this road, so I'm just trying to avoid making a mistakes and want to get it rite the first time. Thanks
I used the EZ-wire. I think it was 20 or 21 circuits. I didn't need that many, but just saved the extra wires in case I want to add something later. Stuffed the extra wires in the drivers side kick panel. I would order as many circuits as you can and save any extras.
I looked at the Painless, but just couldn't justify the higher price. EZ-wire worked out fine. I did have one question and called their tech support and got a good answer.
I mounted the fuse box under the dash up high, just to the left of steering column.
I have seen some kits that each wire is labeled every so many inches and I do like that feature. I have a engine harness for the Mark VIII 4.6 coming from the Detail Zone, they were about the only choice for that. Also I have a steering column from a 91 Econoline with the key and PRND in it, that looks like it would fit??
Ron Francis and Painless are very "proud" of their kits (read want $$$$$). They were the first and charge for their name. I like my EZwiring mini 21 circuit kit I mounted my panel under the dash on a quick release bracket so it can be dropped down for trouble shooting if needed. You could mount it in the drivers side kick panel (use modern quick release rivets to hold the panel cover in place), under or behind the seat or even in the glove box, especially if you have one of those shallow glove boxes for AC clearance.
I used a Rebel harness. Good quality product with multiple colored (and proper gauged wire) labeled every 6 inches. They make several models according to how many circuits you may need. It also came with the plastic headlight connectors w/terminal ends and a fusible link for protection. The price is good too.
If so, these are great kits.
Little backstory: The fellas that started AAW were actually ex-employees/engineers of Ron Francis. That's why there is a striking resemblance to the Ron Francis kits to the American Autowire kits. Now why they peeled off and started their own company... I cannot remember for sure.
I used an American Autowire kit. I mounted it under the drivers side dash on square tubing that runs the entire width of the cab. The tubing also mounts my A/C unit, and is an easy place to run grounds. The wiring kit had good instructions and the one question I emailed was answered promptly. The price was also alot less that Ron Francis.
