Special tools_ Rear Drive Axle/Differential — Ford 10.50-Manual Transaxle/Transmission — ZF 6-Speed
This set includes:
308-375 Remover, Input Shaft Oil Seal
308-379 Installer, Input Shaft Oil Seal Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-380 Centerplate Legs Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-381 Fixture, Gear Pack Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-382 Installer, Output Shaft Oil Seal (4x2) Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-383 Installer, Output Shaft Oil Seal (4x4) Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-384 Installer, Countershaft Rear Bearing Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-387 Sleeve, Shifter Boot
308-388 Installer, Countershaft Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-389 Installer, Centerplate Mainshaft Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-390 Installer, Centerplate Front Bearing Cup Manual Transaxle/Transmission — ZF 6-Speed : Excursion : 2004,F-250/350/450/550 Super Duty 04-2010
308-391 Installer, Input Shaft Bearing Cup Rear Drive Axle/Differential — Ford 10.50-Manual Transaxle/Transmission — ZF 6-Speed
Excursion : 2004,F-250/350/450/550 Super Duty 04-2011
308-393 Collets, Input Shaft Bearing Cup 308 - Manual Transmission / Clutch
$245.00 FOR ALL or best offer- "No reasonable offer will be refused!"
Please Call Ray at 512-845-4844 or raybx01@gmail.com
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
“The tools are not showing in these picture’s, may be missing and does not come with this set”
Ray is not a member any more as far as I know. That post is pushing 4 years old.
You might try the Gmail address in his signature.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Specialtools
Vendor Specials, Discounts, Product Announcements & Group Buys
12-20-2012 10:32 AM
Specialtools
12-19-2012 12:45 PM
Monsta
Events & Happenings
10-05-2002 07:48 PM
