Special tools/F-250/350/450/550 Super Duty;Excursion-Axle -Differential - Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Old 12-20-2012, 10:32 AM
Specialtools Specialtools is offline
Former Vendor
Specialtools is starting off with a positive reputation.
Thumbs up Special tools/F-250/350/450/550 Super Duty;Excursion-Axle -Differential
This Set includes:
205-420 Remover, Wheel Hub Outer Bearing Cup (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-421 Remover, Wheel Hub Inner Bearing Cup (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-422 Installer, Wheel Hub Oil Seal (10 1/2") Full Floating Axle — Dana : F-250/350/450/550 Super Duty;Excursion : 2004-2011
205-423 Depth Gauge, Drive Pinion (10 1/2") Rear Drive Axle/Differential — Ford 10.25/-F150;F-250/350/450/550 Super Duty;Excursion
205-424 Installer, RH Differential Carrier Oil Seal (Dana 50) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004
205-425 Installer, LH Differential Carrier Oil Seal (Dana 50) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004
205-426 Installer, RH Differential Carrier Oil Seal (Dana 60) Front Drive Axle/Differential : Excursion : 2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-427 Installer, LH Differential Carrier Oil Seal (Dana 60) Front Drive Axle/Differential : Excursion :2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-428 Spreader Bar, Oil Seal Front Drive Axle/Differential : Excursion :2004-2005;F-250/350/450/550 Super Duty : 2004-2011
205-429 Installer, Wheel Knuckle Oil Seal Front Drive Axle/Differential : /Front Suspension(2WD) — Four Wheel Drive (4WD) :Excursion : F-250/350/450/550 Super Duty : 2004
$245.00 FOR ALL or best offer- "No reasonable offer will be refused!"
Please Call Ray at 512-845-4844 or raybx01@gmail.com
We accept Credit Cards ( Visa, Master Card, AMEX) -reference available upon request.
Special tools_ Rear Drive Axle/Differential — Ford 10.50-Manual Transaxle/Transmission — ZF 6-Speed Specialtools Vendor Specials, Discounts, Product Announcements & Group Buys 3 07-06-2016 09:44 AM
Question about front axle seal driver (OTC 6695 or 205-429/205-199) queen of spades 1999 - 2003 7.3L Power Stroke Diesel 3 03-18-2015 11:41 AM
Free Shocks!?!? 05-up Ford F-250/350/450/550 Super Duty pick-up/chassis cab 4WD any trim level (Dies doghouserez 1999 to 2016 Super Duty 1 01-17-2015 09:41 PM
Tools set_Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear— Ford 9.75-Inch Ring ;Expedition Specialtools Vendor Specials, Discounts, Product Announcements & Group Buys 0 12-19-2012 09:44 PM
Special tools-Automatic Transmission -4R70E/4R75E- 5R55S, Rear /Front Drive Axle/Differential— Dana Specialtools Vendor Specials, Discounts, Product Announcements & Group Buys 0 12-19-2012 12:33 PM
Tags
diesel, f100, f150, f250, f350+, gas engine, small trucks and vans, suv’s/crossovers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
