2.5 leveling kit ?
2.5 leveling kit ?
i have a 96 f150 4x4 and looking to do a leveling kit. I see the 2" leveling kit, but i wanted alittle more like 2.5. I DONT plan on wheeling this truck ( my work truck ). I know they make a 2.5 suspension kit with drop down brackets for the beans & radius arms, but is that really needed ? Cant i just use 2.5 springs and no brackets ??? i mean a 1/2 inch difference isnt much..... any thoughts ?
thanks
thanks
They are not needed, but I would recommend them, You could do springs and block them if needed to get a 2.5 inch lift. But if you do that the truck isnt going to as stable and will seem more top heavy and on top of that it puts alot more stress on the springs which could end up being dangerous but you could if your experienced or know someone that can just make custom brackets and weld them if you feel the need for more support but want to save money. In my opinion I'd buy an actual leveling kit though.
Iowan-
If you didn't touch the allignment then your wheels must be like \--/ when looking at the front of the truck. Mine were WAY out when I put the 2" spacers in. Lifting the TTB WILL cause camber to go out at the top. There's no way around it... Cost me $400 for the allignment after installing the spacers because they had to fight to get the camber where it should be. I realized then I should have put that 400 towards a 4"lift with all the drop brackets instead
XLT GOLD 84
04-09-2015 11:52 AM
