Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 12-19-2012, 07:52 PM
acfordhawk acfordhawk is offline
Garage is empty, add now
acfordhawk is starting off with a positive reputation.
Mustang II kit install
I am currently working on a Mustang kit install and wonder if anyone has worked through the whole process and what kit they used and any tips on making it flow together. Tried a search but got a whole bunch of different topics and not really covering an actual install. Thanks, Paul
  #2 (permalink)
Old 12-23-2012, 07:16 PM
okiewelder okiewelder is offline
okiewelder is starting off with a positive reputation.
mustang II
I have a fatman mustang two that I installed a few years ago. I have never gotten the truck on the road to report how it handles. It was pretty straight forward. What kind of questions do you have?
  #3 (permalink)
Old 12-25-2012, 09:40 AM
I have the Fatman kit and currently got the old axle pulled and boxing plates welded in. Even though the plans and directions are good just wondered if there are any other details or tricks to make the work easy. Looks like mostly time and accurate measurements rather then a lot of heavy fabrication.
  #4 (permalink)
Old 12-25-2012, 09:46 AM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is offline
1966 Ford F-100
37 Ford guy is gaining momentum as a positive member of FTE.37 Ford guy is gaining momentum as a positive member of FTE.
Just curious if the instructions on those kits recommend moving the axle center line forward 1-1.5" to center the front tire better in the wheel well?
  #5 (permalink)
Old 12-25-2012, 12:07 PM
mustang 2
I think it reccomends a inch forward. I tig welded the hats on because that just looked better. Yea just measure it and measure again and tack and measure and then do the final welding.
What are you doing for the back end? I wish I had seen the lincold irs kit that is on the market before I c'd the back of my frame. I think that would be cool to have that under my truck.
  #6 (permalink)
Old 12-25-2012, 04:48 PM
I'll look through the instructions again but not sure if it mentioned the 1" forward movement. Just putting drop monoleafs on the back and a disc brake conversion. Saw the IRS set up and decided to keep the 9", think my planning for the gas tank relocate would have had some interference.
  #7 (permalink)
Old 12-26-2012, 02:22 PM
There isint much room on the back end when you start dropping it. I would like to go to a 4 link eventually but I just put my rearend ontop of the springs and took a couple out so it will ride a little better.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
