cummins conversion - Ford Truck Enthusiasts Forums
cummins conversion
Old 12-19-2012, 02:45 PM
backwoods72 backwoods72 is offline
backwoods72 is starting off with a positive reputation.
cummins conversion
ok newby here, and maybe this came up some time ago, i have not looked back too far, but has anyone done this conversion, i have a 1978 F250 crew cab w/ 460 C6 auto trans, wondering what is all envolved in the conversion to a 12V cummins, i live in alaska so i know the cost will be more then you fellas in the lower paid to have this done , but just wondering.
thanks
Old 12-19-2012, 02:56 PM
vic_v8 vic_v8 is offline
vic_v8 is starting off with a positive reputation.
yes, done many times, I can't remember the user on here, but it has a built thread. Also look at the 4btswaps.com page and google fummins
Old 12-19-2012, 03:11 PM
right on thanks i will look for it
Old 12-19-2012, 08:13 PM
crrnchris's Avatar
crrnchris crrnchris is offline
crrnchris is starting off with a positive reputation.
Old 12-19-2012, 08:15 PM
asweetroy asweetroy is offline
asweetroy is starting off with a positive reputation.
P pump or stay home on all cummins swaps
Old 12-19-2012, 09:49 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Quote:
Ya, 400+ horsepower out of a rotary VE pump just doesn't cut the mustard.
Old 12-20-2012, 11:46 AM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Lots of cummins swaps going on down in the "motor swap" forum on here including mine.
Old 12-22-2012, 02:08 PM
jimlj jimlj is offline
jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.
Quote:
thanks
Is your truck a 2 wheel drive? If so I have heard there is a problem with oil pan and steering linkage. You may be able to find a pan that won't get in the way.
If you have a 4X4, you have to cut about half of the front cross member out and box it back in. You will have to fab your own motor mounts, transmission mount, lengthen front and shorten rear drive lines.... Don't get me started.
If you can fab/weld/visualize, and look on line at others pictures and description of how they did their swap, it is not that hard, and at least for me a good diversion from the job that puts food on the table.
Question for the guys that have done a fummins conversion uh60 1999 to 2016 Super Duty 0 10-30-2016 03:03 PM
Anyone powerstroked a 70's f serie's? Brycemunro Engine Swaps 6 09-02-2013 03:14 PM
Anyone here ever done a 5.9 cummins swap? (03-06) JohnDeereFarmerUSMC 1999 - 2003 7.3L Power Stroke Diesel 4 09-24-2012 01:36 AM
More Cummins Conversion Questions 1972RedNeck 1973 - 1979 F-100 & Larger F-Series Trucks 14 07-27-2012 09:16 PM
5.4 cummins conversion whitechocolatefrogs 1999 to 2016 Super Duty 33 12-29-2011 12:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
