Tire pressure monitor problems - Ford Truck Enthusiasts Forums
Old 12-19-2012, 12:55 PM
deputypq920 deputypq920 is offline
deputypq920 is starting off with a positive reputation.
Today on the way to work the tire pressure idiot light began to blink and a message came on and said "Tire Pressure Monitor Failure" or words to that effect. About a minute later they both went off and didn't come back on. Whats up with that? Also, how do I know which monitor, if any, is going out?
This on a 09 Screw with 49K on it.
Old 12-19-2012, 01:49 PM
FORDSVTPARTS FORDSVTPARTS is offline
Former Vendor
FORDSVTPARTS is gaining momentum as a positive member of FTE.FORDSVTPARTS is gaining momentum as a positive member of FTE.
Did you check your tire pressures?
Old 12-19-2012, 02:33 PM
No, I havn't had a chance to put a guage to them yet, but they look normal. I'll check that when I get home.
Old 12-19-2012, 08:35 PM
awq134's Avatar
awq134 awq134 is offline
awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.awq134 has a good reputation on FTE.
i didn't know that 2009's had the tpms. is it just on certain models? I have a 2010 STX that doesn't have it. I'm kind of glad that it doesn't have it. The wife's car had a sensor go bad so there was always a light on the gauge cluster blinking.
Old 12-19-2012, 09:28 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
Quote:
Does your spare tire look normal too?
My little brothers 08 STX had the light come on and his spare tire was low on air.
Old 12-19-2012, 09:48 PM
Going_Going_Gone Going_Going_Gone is offline
Going_Going_Gone is gaining momentum as a positive member of FTE.
The other morning it cooled off overnight and my son's and my trucks had TPMS lights go on. The day before it was warm enough to not trigger the light, but the sudden cool-down brought the pressure down enough. I checked my pressures, all were low, but one of them was down to 25 psi. My guess is that your tire(s) were just at the low pressure limit that triggers the light...then driving it warmed them up enough to expand the air and the light went off.
Old 12-20-2012, 05:38 AM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Well you either have a low tire pressure or one of the sensors needs replacement. The batteries on them usually last about 3-4 years before needing replacement.
Old 12-20-2012, 06:57 AM
Chris Anchor's Avatar
Chris Anchor Chris Anchor is offline
Chris Anchor is gaining momentum as a positive member of FTE.Chris Anchor is gaining momentum as a positive member of FTE.
You can have the dealership set the monitor level to a different PSI. I did as I wanted my monitor to tell me at 50 PSI. I inflate mine to 55 lbs, I prefer a harder ride. Chris
Old 12-20-2012, 08:14 AM
I checked the pressures last night and all were fine, including the spare. The weather here has been rather warm, 75 degrees in the afternoons, though a cold front is coming through today. The wierd part was that the sensor blinked, and it gave a sensor problem warning message. I had been driving about 20 minutes at 40-50mph. Also, how do I tell which sensor may be going out? On my friend's Chevy it tells you which tire is low. This is just a non specific warning. I don't want to change all five of them if only one is bad.
Old 12-20-2012, 09:13 AM
The dealer can tell you which one it is.
Old 12-20-2012, 10:22 AM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
stephen.osborne1 is gaining momentum as a positive member of FTE.stephen.osborne1 is gaining momentum as a positive member of FTE.
I've had the same problem... I figured it was due to radio interference, as each time it has gone off, I was going through a city. I was not aware that the dealer could change the pressure level for it to signal at... I think I'll have to have my dealer adjust mine, as I have Toyos on my truck and I like a little harder ride too.
Old 12-20-2012, 11:48 AM
Jimbits78's Avatar
Jimbits78 Jimbits78 is offline
Jimbits78 is starting off with a positive reputation.
It's not tire pressure. If it was it would say low tire
I have the same thing happen on my 2010 every 5-6 weeks. It will show the tire monitor fault for a few minutes then go out. This started happening after the tire shop switched my sensors over to my new rims.
Old 12-20-2012, 03:34 PM
Quote:
I'm certain they can, for $50 an hour. I don't like the Ford service department near my house, especially since they literally left me out in the cold once before.
Old 12-21-2012, 10:19 PM
wwilson43 wwilson43 is offline
wwilson43 is starting off with a positive reputation.
Quote:
TPMS became mandatory in the 07 models, your 2010 STX does have it unless you bought the truck used and someone changed out the rims
Old 12-22-2012, 12:25 AM
$50 an hour would be cheap here!!
Aftermarket Tire Pressure Monitor System flysniper 1999 to 2016 Super Duty 2 12-07-2016 04:40 PM
Trailer camera? johndeerefarmer 2017 Super Duty 5 10-13-2016 02:03 AM
Disable TPMS? dave3406 1999 to 2016 Super Duty 46 04-14-2016 07:23 AM
Tire Pressure Monitoring System nut1605 6.7L Power Stroke Diesel 11 11-28-2010 11:06 AM
Tire Pressure Monitor wildryd71 Expedition & Navigator 17 03-16-2006 07:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
