1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Mustang II kit install
Old 12-19-2012, 07:52 PM
acfordhawk's Avatar
acfordhawk
acfordhawk is offline
I am currently working on a Mustang kit install and wonder if anyone has worked through the whole process and what kit they used and any tips on making it flow together. Tried a search but got a whole bunch of different topics and not really covering an actual install. Thanks, Paul
Old 12-23-2012, 07:16 PM
okiewelder's Avatar
okiewelder
okiewelder is offline
mustang II
I have a fatman mustang two that I installed a few years ago. I have never gotten the truck on the road to report how it handles. It was pretty straight forward. What kind of questions do you have?
Old 12-25-2012, 09:40 AM
acfordhawk's Avatar
acfordhawk
I have the Fatman kit and currently got the old axle pulled and boxing plates welded in. Even though the plans and directions are good just wondered if there are any other details or tricks to make the work easy. Looks like mostly time and accurate measurements rather then a lot of heavy fabrication.
Old 12-25-2012, 09:46 AM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
Just curious if the instructions on those kits recommend moving the axle center line forward 1-1.5" to center the front tire better in the wheel well?
Old 12-25-2012, 12:07 PM
okiewelder's Avatar
okiewelder
mustang 2
I think it reccomends a inch forward. I tig welded the hats on because that just looked better. Yea just measure it and measure again and tack and measure and then do the final welding.
What are you doing for the back end? I wish I had seen the lincold irs kit that is on the market before I c'd the back of my frame. I think that would be cool to have that under my truck.
Old 12-25-2012, 04:48 PM
acfordhawk's Avatar
acfordhawk
I'll look through the instructions again but not sure if it mentioned the 1" forward movement. Just putting drop monoleafs on the back and a disc brake conversion. Saw the IRS set up and decided to keep the 9", think my planning for the gas tank relocate would have had some interference.
Old 12-26-2012, 02:22 PM
okiewelder's Avatar
okiewelder
There isint much room on the back end when you start dropping it. I would like to go to a 4 link eventually but I just put my rearend ontop of the springs and took a couple out so it will ride a little better.
ahawes
05-14-2009 03:31 PM
goda123
12-04-2008 10:05 AM
Voh
33
02-21-2008 10:50 AM
iwannabebig
01-09-2005 08:29 PM
Quick Reply: Mustang II kit install
