1973 f100 ranger chassis swap - Ford Truck Enthusiasts Forums
Old 12-19-2012, 12:52 AM
myfirsttruck916 myfirsttruck916 is offline
myfirsttruck916 is starting off with a positive reputation.
I have a f250 ranger xlt camper special chassis i did a body swap on and mt blinkers are on when i turn the key to the right once and my reverse lights are constantly on. I did a bypass on the nuetral saftey switch because the one i had was shot could that be the issue on the reverse lights? And the blinkers could it be my column? The column is in grat shape and it came from a near mint condition truck that i got the chassis from. Help will be much needed thanks
Old 12-19-2012, 08:53 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
I'm not clear on what you did. You say 73 f-100 ,is that the body ? Then f-250 chassis, what year chassis ? Is it mounted on a newer chassis ?
Old 12-19-2012, 12:14 PM
Same year chassis and body
Blinker Issue 77_f250_custom 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-12-2015 07:00 PM
New Tires and No Blinkers KJNDIVER 1999 - 2003 7.3L Power Stroke Diesel 6 10-19-2012 12:44 AM
1987 f-150 Pickup Blinkers Not working. Michael McQueen 1987 - 1996 F150 & Larger F-Series Trucks 5 02-26-2012 01:14 PM
blinker problem 79 ranger 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-31-2011 11:00 AM
Bad turn signal switch? wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 10 07-25-2011 02:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
