Computer Module Location
Where is the Computer Module located on a 2004 CC 6.0L?
I replaced the battery in my keyless entry keypad and I need the code to reset the keypad. The radio has been replaced so it is not on the bottom of the radio. I have never known the code as the previous owner did not supply to the dealer when he traded it in. I have carried it to the dealer right after I bought the truck and they could not get the code for me using the scanner.
This keypad is not original as it is dated in 2006 when I opened it to replace the battery. It may be aftermarket and not FORD but it has no manufacturers markings that I can find.
Supposedly the control module has the key code printed on a label on it.
This sounds like same issue. Hope it helps you. https://www.ford-trucks.com/forums/1...m-picture.html
REDDOG_0_0_7
1999 to 2016 Super Duty
13
10-14-2013 09:45 AM
