VCT solenoids or cam phasers? - Ford Truck Enthusiasts Forums
Old 12-18-2012, 10:01 AM
heatseaker1 heatseaker1 is offline
heatseaker1 is starting off with a positive reputation.
Ok, here's the scoop. I've got a '06 xlt with a 5.4 3V and several months ago it started acting up. At first it was just when in reverse then it was anytime i was operating under low rpms like in a parking lot or such. It would miss/knock/shudder. Kinda sounded like a bad running diesel. It also kinda rattled during acceleration up to 1500 rpms or so. It would only do this after being warmed up. When cold it was fine but after getting warmed up it got to the point that it would act horrible. I replaced the timimg chains, tensioners and guides thinking that was the issue and it was not. After reading a bit on the cam phaser and VCT issues that folks have had with this engine I unplugged the VCT solenoids and low and behold the noise is gone, the missing/bucking/diesel sound is gone and there is little to no noticible loss in performance. Now I don't want to drive it like this forever but will until I determine the cause. I was wondering if anyone can give me any clear insight into what is the culprit. Is the solenoid or the phasers?
Thanks
Old 12-28-2012, 04:42 PM
JoSHN JoSHN is offline
JoSHN is starting off with a positive reputation.
Since you have the easier valve covers to do this on, I would suggest pulling out your VCT's just to inspect and possibly eliminate them from the equation.
VCT Solenoid
You should be able to use this step by step and get to the VCT's with ease. Unless, however, your valve cover does not have the easy to remove seal around the VCT's.
I replaced the VCT's on my 08 (which is not as easy as the earlier years as you have to remove the entire valve cover to get to them). Once the VCT was out, I noticed damaged screens on it. That narrowed it down pretty quickly for me.
Also, if you do end up replacing them, as unlikely as it sounds you should call up your local stealership for the part. It might actually be cheaper. At least it was in my case. By $120.
Old 12-28-2012, 04:51 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
I have replaced several solenoids for noise and running concerns . Not just Ford products . The screens seem to be the main issue . They plug and or come apart . Make sure you use the correct weight oil also .
Vct electrical issues Mikesqm900 2004 - 2008 F150 3 10-18-2016 08:09 PM
2005 5.4 ticking 05fordf150 2004 - 2008 F150 1 04-25-2016 09:13 PM
08 f150 knock f150guuy 2004 - 2008 F150 1 09-04-2014 01:59 AM
Phasers or VCT solenoid?? shepshu 2004 - 2008 F150 24 03-07-2014 12:00 AM
Questions about VCT System - P0012 and P0021 Codes jtillery Expedition & Navigator 6 02-15-2014 02:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
