390 crank sprocket
390 crank sprocket
I went to replace the timing chain today. The old one came off no problem (holy crap, tons of slack!!!) and I neglected to look at how the sprockets came off (which direction forward). I've got a new Cloyes kit to go on which comes with sprockets and the chain and figured out which way the cam sprocket goes on pretty easy due to the eccentric for the fuel pump but the crank sprocket confuses me a little more. The concave part of the sprocket faces towards the rear of the truck and the flat face towards the front correct?
And really Ford? Nylon teeth on the cam sprocket? Really?
The oil slinger is that disc that slips over the crank snout after the sprocket is on correct?
One more question.
The locating pin for the cam sprocket. The new timing kit didn't come with one so I knocked it out of the old sprocket and inserted it into the new one. It seems to slide much easier in the new one than the old. Im not worried about it backing out or anything because I see that the cam eccentric has a tab that goes into the other side of the pins hole and would keep it from backing out of the cam completely. It does however make me uneasy putting the sprocket onto the cam itself cause I can't tell for sure if its seated correctly. Am I just worrying for nothing? When the kit is installed I can't hardly get any movement out of the sprocket rotating side to side but the chain is also in much better shape than the old so its hard to tell.
One more question.
Lol I figured out my own question just sitting here. I just inserted the pin into the cam first, then slipped the sprocket over it.. So simple... I was trying to put the sprocket on with the pin already in it... Duh...
One more question though. Below is a picture of how i've got everything installed (aside from the eccentric and oil slinger) Does this look correct? I've got the keyways vertical how it looks like in the Chiltons manual I have. There is a timing mark on the cam sprocket pointing straight up though... Im certain its on TDC compression on #1 and I didn't move anything taking the old chain off so its gotta be fine. Just want an opinion. As I said in another post this cam-in-block V8 stuff is all new to me. Im here to learn!
Yup, it's 180 degrees out. Both sprockets will have timing marks on them. Both of these marks face "out" so you can see them. They are aligned so they are next to each other. The crank mark is at 12:00 O'clock. The camshaft gear timing mark is at 6:00 O'clock.
Like Canus said, look at the picture I posted, you can see the marks. Just a note, in the picture the crank gear is set up so I can advance or retard the cam. That's why there are multiple keyways.
Nahi left the chain on like it was in the pic i posted above and put the crank bolt back in so i had something to rotate the engine with. Spun the engine aroind once (360 degrees on the crank) which brought the timing marks into alignment where they should be. I never rotated either the crank or cam independently of each other. I must just have made a mistake when finding tdc compression before removing the timing cover. Does this make better sense or am i still missing something?
Luckily the distributor is already out. Lol. Or i should have said unluckily... Would havebeenmuch easier to find the correct timing orientation by just looking at the direction of the rotor. Oh well. Live and learn.
I really appreciate everyones help and patience. This is sure a friendlier online environment than alot of others i have experienced!
