6.0 alternator
6.0 alternator
Well, I finally got tired of replacing my "lifetime" alternator every 12 - 18 months from autozoo. Between the cheap parts and the recent deal firing an employee for defending himself and his co workers, I'm done with them.
I figured an upgrade would be nice, but didn't want to spend $300 or more for an online one. I like the idea of local parts stores warranties, so I went to Oreilly and picked up a 140 amp alternator for a 6.0 truck instead of the little 110 amp they sell for ours.
The case is just a hair larger, but the mounting holes line up the same. The pulley is larger on the 6.0 alternator, but I swapped the pulleys out so it's no big deal.
One of the tabs on the alternator where the screws that hold the case together hits the alternator bracket on our truck, so the options are either shim the alternator with washers, or hit the bracket real quick with a grinder. I started to use the washers, but it seemed like a pain after I dropped one washer so I grabbed the grinder. Some quick work at the center of the bracket and it fits like a charm.
The connectors on the back of the alternator are off about a quarter turn. I was going to take the case apart and clock it so everything faced the same direction, but the sun was setting fast and the plug was turned toward the harness so it created extra slack. I think I'll take it back apart later and clock the case to the original position, but this will work for a few days. As it sits now, I have to use a wrench to tighten the charge wire bolt since a socket would hit the CAC tube.
I'm going to add a secondary charge wire this weekend, so I'll get some more pics then if anyone's interested.
Reps if I can! Great post, thank you!!!!!
Yeah, I don't understand why people do this (although it can't hurt). That fat wire goes over to the pass-side inner fender and connects to the starter solenoid - where fat wires go directly to the batts. I don't see any gain from adding another wire - surely that wire is capable of carrying this load and then some.
Very nice write Chris ! Was that a new one from O'Rielly if so do you have part# ? Also I think I am missing some of the back story as far as the AutoZoo employee??? Could you please explain?
Heroic AutoZone Employee Fired for Using Gun to Thwart Armed Robbery | Fox News Insider
They only charged me $5 for a core charge, which has got to be some kind of mistake I'm guessing, but I'm thinking about hanging onto the old one and maybe finding some rebuild parts in a DIY kit, or turning it into a paperweight, or something.
