Just did some lower end work on 97 psd 128k motor and went ahead and removed the timing cover and new gaskets for it. When re assembling everything, is there any special procedure to prep the low pressure oil pump for the initial starting? The oil is completely drained from the engine so there will be some air in the system at first, thanks again, Ron
just going through my checklist and seems like the fel pro gasket set for the timing cover don't include the oil cooler to timing cover gasket............time to go hunt one down for less than $70
