What should I buy?
What should I buy?
Looking at buying a newer/used truck…..<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
What my needs are; <o></o>
<o></o>
1. Not a daily driver<o></o>
2. I have a budget of 10,000 to 15,000<o></o>
3. Prefer 4x4 because in the winter months I travel to snow area often like snowboarding<o></o>
4. summer moments would involve pulling a boat and/or cabover camper so I think a F350?<o></o>
<o></o>
I have no preference for Gas or Diesel…lifted or not….or engine size.<o></o>
<o></o>
I’m interested in hearing feedback with good or bad models for my needs that I mentioned above.<o></o>
<o></o>
Thanks for reading and commenting<o></o>
Joe<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
Joe<o></o>
Absolutely get the F350. You didn't say which cab you wanted, regular cab, super cab or crew cab. Since its not a daily driver, I would recommend the F350 single rear wheel, with the V10 gas engine, auto trans and you choice if cab configuration. You can add air bags if you need them. Also you have an option to get a F350 with dual rear wheels which will help with stability when hauling the camper but I think if the camper is under 3500lbs. you will be fine with single rear wheels.
Different cab configurations have different GVWR(gross vehicle weight ratings). For example my '08 F350 crew cab v10 long bed has a CVWR of 11,200lbs, where a super cab F350 might have a GVWR of 11,000lbs. A super cab truck would weigh less than a crew cab thus the difference in GVWR. The Diesel option in those same trucks would have a higher GVWR because the Diesel engine itself is heavier than a gas engine, so Ford raises the GVWR so it has the same carrying capacity as a gas truck. Make sense?
05-08 V10 DRW 4.30 gears and whatever configuration you want! If the vehicle is not a daily driver then do not go diesel. Im not trying to start a war but diesels need to be driven and warmed up otherwise you will have issues. IMHO it is not worth the extra maintenance cost if its only going to be used a handful of times per year.
Awesome, exactly what I was looking for!!
F250's have a max GVWR of 10,000lbs. regardless of cab. That's why I suggest a F350. Depending where you live, you might never get a second look from the man, but I have to watch my weight because trucks in my area are always getting pulled over and weighed. However they almost never pull over someone who has an RV, unless that person is driving in a dangerous manner.
Good info, will keep that in mind when I am looking.
Thanks!!
Thanks!!
