1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 F250 PCM picture?
Old 12-17-2012, 02:26 PM
jameseric's Avatar
jameseric
jameseric is offline
I just purchased my F250 and I do not have the key-less entry code. The dealer wants more than I want to pay if I can find the code myself. I have searched this forum and I have seen pictures of the PCM on Ebay. I have pulled the passenger glove box, the drivers glove box and the fuse cover on the drivers side. Does anyone have a picture so I can see where it is hiding?
Can someone please help me find it so I can get that should be written on the PCM?
Thanks,
James
Old 12-17-2012, 03:04 PM
mrcllusb's Avatar
mrcllusb
mrcllusb is offline
If i'm correct its on the drivers side in the engine bay next to the battery
Old 12-17-2012, 03:47 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
just make your own code, follow the steps in the manual and change it. plus its free
Old 12-17-2012, 03:49 PM
SuperDutyScaler
anyway what are they charging you for? all the have to do is look up your vin and give you the factory code its about two minutes for them to do it
Old 12-17-2012, 06:18 PM
jameseric's Avatar
jameseric
My battery is on the passenger side but will look in the engine bay. I can't set a new code without first entering the factory code. The dealer claims they need to hook up a computer to get the code. I will crawl under the hood in the morning and see if I can find it. Behind the glove box is a black panel with 5 or 6 bolts. Could it be behind that panel?
Old 12-17-2012, 06:26 PM
PSDlongbox's Avatar
PSDlongbox
PSDlongbox is offline
call a different dealer. Our dealer was more than happy to give us the code via VIN lookup. We had to come into the parts department with proof of ownership (registration) and it took them all of 2 minutes to look it up.
Old 12-18-2012, 10:50 PM
SmokyMountain's Avatar
SmokyMountain
SmokyMountain is offline
Jameseric, while under the hood look on the driver's side. there are two batteries. What you are looking for is not under the hood. It is under the dash behind the radio. If you still have the original radio it should be printed on the back of the radio.
Old 12-19-2012, 06:29 AM
jameseric's Avatar
jameseric
Thanks......
canadajin
Modular V10 (6.8l)
07-04-2009 06:18 PM
scram98400jm
06-23-2009 08:26 AM
varmintboy54
05-14-2009 07:53 PM
centralil
05-29-2007 12:20 PM
BillAV8R1
11-15-2006 07:30 PM
Quick Reply: 2006 F250 PCM picture?
