Water in fuel already drained keeps coming back - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 12-17-2012, 02:11 PM
ssoulis ssoulis is offline
ssoulis is starting off with a positive reputation.
Hi there, I have a 1999 f350 7.3 diesel. I have been recently having difficulty with the water in fuel. I thought it had to do with the filter so I replaced it. I have drained the fuel filter compartment and it keeps coming back. My truck will not start unless I drain the fuel, refill, and charge batteries so I have enough amps to crank over. Is there a fuel/water separator that needs to be replaced? Or does it just collect in the fuel filter compartment?
Old 12-17-2012, 02:21 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
There is probably water in your tank that keeps causing this. Try running a bottle of diesel 911 in the tank mixed with some fresh fuel. If you keep trying to start it like that you can do damage very fast.
Old 12-17-2012, 02:37 PM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
may have to drain the tank.
Old 12-17-2012, 02:49 PM
BillyBob69's Avatar
BillyBob69 BillyBob69 is offline
BillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to allBillyBob69 is a name known to all
What they said^^^
It keeps coming back cause its probably in the tank. Depending on how much is in there, I would try the 911 first then if that fails, drain the tank and try again. But remember, there is going to be some in the lines so after doing either option, I would cycle the key a few times with the bowl drain open to make sure that you clear the lines before trying to inject water into the cylinders.
Old 12-17-2012, 02:53 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Did you save the fuel you drained and let it settle and see water at the bottom? If there actually isn't any water the WIF sensor is bad.
If there isn't any water in fuel disconnect the white WIF/Fuel bowl heater connector on back of fuel bowl and you will be able to start. Then you can get a new sensor when possible.
I've been running for a couple of years with that connector unplugged.
Old 12-17-2012, 04:37 PM
Diesel 911. Where do you get it? I actually see a bit of water in what I drained. It is a little wet outside but I am pretty sure it came from the fuel. I still have a half tank...not happy.
Thanks
Old 12-17-2012, 05:04 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
Most auto parts stores and Walmart carry this kind of stuff, especially this time of year. Truck stops will have it, too.
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
Thanks
Walmart carries it...
Old 12-17-2012, 06:20 PM
Thanks! Hopefully this works and I wont need to drain tank.
Old 12-17-2012, 09:47 PM
nlemerise's Avatar
I would...all that water going through injectors is not a good thing.
Old 01-10-2016, 01:56 AM
xnavy_et xnavy_et is offline
xnavy_et is starting off with a positive reputation.
Not sure if I am going to get a response to this since all of the other posts were from 2012, but here it goes anyway. I just bought a 2011 F250 6.7. Before I got it home, I had a water in fuel filter light come on. I have read the forums and tried draining the separator, with no water. I have even changed the filters. Nothing short of taking it to the dealership fixed the issue. So I did, and they said that I had a bad sensor and a bad cap. After spending $320, I was back on the road and happy. The next day the issue came back. Still no water in the fuel. I even tried unplugging the sensor and the light is still on.
Old 01-10-2016, 06:49 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
You may want to revisit your search and specify the 6.7L Powerstroke forum. This is the 7.3L forum, and the response would be what one could describe as anemic.
Old 01-10-2016, 06:50 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Sounds like they didn't fix the problem. Remember reading this years ago in the 6.7 forum. Get on there and get an answer. I'd take it back and tell them parts only. That should be covered.
Old 01-11-2016, 10:48 AM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
It IS nice to see a thread with Payson participating in it though. Here's to you brother...
Quick question about draining off water... troverman 6.7L Power Stroke Diesel 19 12-02-2015 07:49 PM
f350 diesel water problem Wbratberg 1999 to 2016 Super Duty 15 10-07-2014 09:17 PM
1988 F800 7.8L 474 turbo no fuel - air? brushwolf General Diesel Discussion 8 04-01-2013 07:36 PM
help, 7.3 diesel fuel filter does not drain??? tycot1 1987 - 1996 F150 & Larger F-Series Trucks 6 12-10-2011 10:19 PM
Water Separator TomA92 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-13-2007 11:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
