Almost had a blowout. Thanks!
Have been hearing what kind of sounded like an exhaust leak on my '00 Excursion V10 for a couple weeks now. Thought I'd check it out whenever I finally get a day off work. After cruising thru the spark plug blowout threads yesterday I thought I better check mine ASAP. Tore into it last night after work and #4 was loose and leaking by and causing the noise. New plugs, antisiezed and torqued to 20ft lbs. Sure beats installing an insert. Thanks guys.
Ricohman
Modular V10 (6.8l)
06-12-2006 11:58 PM
