Key fobs won't program... kind of...
Here's the deal. I bought 2 new fobs off of eBay. The one that came with the truck didn't work. I did the program and it works perfect. I program the second it works as well, but then the first one doesn't. I did the old one and it works fine, but then the last one doesn't. Do a new one and same thing, it's the only one that works! WTH?!?
To program the transmitters yourself:
1. Insert a key in the ignition and without starting your car, turn the key from OFF to ON eight times in rapid succession (within 10 seconds) with the eighth turn ending in the ON position.
2. The doors will lock/unlock to confirm that programming mode has been entered.
3. Within 20 seconds, program a remote transmitter by pressing any button on the transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure must be repeated.
4. Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
5. When you have completed programming the remote transmitters, turn the ignition to OFF, or just wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Hello,
At step 3 you should press a button on each transmitter that you want to program. Step 4 kind of indicates you should start from step 1 again, but what that does is wipe out the programming on the remote you just programmed - that's why you're only getting one transmitter programmed at a time.
Hope that helps!
Hope that helps!
Patriot_RAM
10-31-2023 04:16 PM
That_Guy
08-15-2009 11:56 AM
fordiesel69
09-25-2008 09:50 PM
