How do I disable the fuel pump to do a compression test? - Ford Truck Enthusiasts Forums
Old 12-17-2012, 05:42 AM
Smellii's Avatar
Smellii Smellii is offline
Smellii is starting off with a positive reputation.
1969 F100 360
I know some of my valve seats are trash because I can see exhaust coming from my valve covers. When I do a compression test to see which ones need recut fuel sprays out of the unplugged cylinders. :\
Thanks in advance.
Smellii
Old 12-17-2012, 08:34 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
I don't disable the pump, haven't had any problems.
Old 12-17-2012, 08:47 AM
OverReved OverReved is offline
OverReved is starting off with a positive reputation.
Prop the throttle open all the way. At cranking speed with the carb open all the way there will not be enough vacuum created to draw fuel out of the carb. If you still get fuel spray out of the spark plug holes, then you also have a carb problem. Good luck.
Old 12-17-2012, 10:41 AM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
fuel spraying out spark plug holes ? all the engines i have tested none have done this . something don't sound right .
electric or mechanical pump ?
Old 12-17-2012, 12:30 PM
Freightrain's Avatar
Freightrain Freightrain is online now
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
Exhaust from the breather is not a valve issue. That is worn compression rings, blowing air down into the block and out any open hole.
If you have gas blowing out a cylinder, then you have carb issues. I've never had to disable the pump to do a compression test. Leaving the carb alone, it should not draw that much fuel to get wet.
Old 12-17-2012, 07:51 PM
willowbilly3 willowbilly3 is online now
willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.willowbilly3 has a very good reputation on FTE.
Same here, done hundreds of compression tests and never had gas spray out. Also, If you tear it down, ALL the valves/seats/guides/springs need brought back to factory spec, not just the worst ones.
Old 12-28-2012, 06:53 PM
Smellii's Avatar
Ok. Thanks fellas.
Old 01-05-2013, 06:13 AM
BigBlockMan's Avatar
BigBlockMan BigBlockMan is offline
BigBlockMan is starting off with a positive reputation.
Quote:
Originally Posted by Smellii View Post
1969 F100 360
Thanks in advance.
Smellii
I'd say at this age they are all wore out.
How to disable electric fuel pump while cranking? quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 08-19-2013 02:17 AM
Modern transmission in a 69 F100 Smellii 1967 - 1972 F-100 & Larger F-Series Trucks 7 02-10-2013 11:22 AM
Ugh! Where do I put in new oil? Smellii 1967 - 1972 F-100 & Larger F-Series Trucks 3 12-23-2012 12:48 AM
Valve seat cutting. Smellii 1967 - 1972 F-100 & Larger F-Series Trucks 3 12-17-2012 02:23 PM
heli-coil or something else for stripped threads on carb fuel inlet? Smellii 1967 - 1972 F-100 & Larger F-Series Trucks 9 11-27-2012 02:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
